08-20-2008, 22:13 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Mirpur-1, Dhaka,Bangladesh
Member: 222009 Status: Offline Sonork: 100.1576751 Thanks Meter: 435 | Dead By Pinfinder ITS PIN OUT IS 1.........24 11: Gnd 12: Tx (RJ-45 pin-3) 13: Rx (RJ-45 pin-2) 15: +charge BUT PINFINDER CANT DETECT IT AND THE SET IS DEAD NOW... I CANT UNDERSTAND HOW THE SET BECOME DEAD WITH PINFINDER EVEN IT CAN'T DETECT IT'S PINOUT ... |
The Following User Says Thank You to sharmin For This Useful Post: |
08-21-2008, 06:46 | #2 (permalink) | |
No Life Poster Join Date: May 2008 Location: COME & MADE GREEN WORLD
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | Quote:
Press any phone key from time to time to wake-up phone. detecting pins.... GOOD LUCK TRY AGAN. | |
The Following User Says Thank You to debmobile For This Useful Post: |
08-21-2008, 16:31 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | It's not possible to damage phone during PinFinder usage. If your phone was able to Power-On from PinFinder during pinout detection process but can't power-on from battery you must charge battery. |
08-21-2008, 20:55 | #4 (permalink) | |
Member: 222009 Status: Offline Sonork: 100.1576751 Thanks Meter: 435 | Quote:
its my own set not recieved from customer, and it was 100% working before test and now it cant detect even with huawei tool with its cable !!! | |
08-23-2008, 07:47 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | It's not possible to damage phone during PinFinder usage. If phone was unable to power-on during pinout detection this means that you have connected "+" and "-" wires to phone incorrectly. |
08-23-2008, 08:47 | #6 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: Aqua Project Age: 47
Member: 115242 Status: Offline Sonork: 100.1581364 Thanks Meter: 1,638 | Quote:
pinfinder use only for pin detaction pin finder not tuch any ohter hardwars of phone so u can duble cechk your phone battery power button etc....... Br. | |
The Following User Says Thank You to Miftahudin For This Useful Post: |
08-23-2008, 21:21 | #7 (permalink) |
Member: 222009 Status: Offline Sonork: 100.1576751 Thanks Meter: 435 | excuse me to all i m sorry to say that i have minimum experience to understand battery charge and the +ve/-ve connector and that set i was using till test i m not blaming pinfinder, ofcourse it is best device for pin detection but i want to know why it cant detect and how it make it dead pls dont reply again with charge or connector ..... |
08-24-2008, 19:02 | #8 (permalink) | |
You must connect + to + and - to -. If you connect power cable incorrectly (+ to -) you can damage your phone by wrong voltage. So you must be very careful. See PinFinder manual page 12 for more information. | |
08-30-2008, 22:15 | #9 (permalink) |
Member: 222009 Status: Offline Sonork: 100.1576751 Thanks Meter: 435 | sorry again, another huawei 2201 totally short by pinfinder , its also for test and it was running set too so where is the problem with this , pls check on huawei 2201 and 2205 i have told before about batt connector ... and for this time i m 100% sure that i m right for the second test so is it better to not to use pinfinder with those cdma sets ??? |
08-30-2008, 23:46 | #10 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: .:iTRi:.
Member: 240068 Status: Offline Thanks Meter: 201 | Quote:
is the read CABLE is + ? ... | |
The Following User Says Thank You to .:iTRi:. For This Useful Post: |
08-31-2008, 08:39 | #11 (permalink) |
Member: 222009 Status: Offline Sonork: 100.1576751 Thanks Meter: 435 | cable out put is ok i m working fine with my pinfinder , but for that set it become short after test |
08-31-2008, 08:46 | #12 (permalink) |
No Life Poster Join Date: Sep 2003 Age: 43
Member: 39948 Status: Offline Thanks Meter: 68 | tested with huawei c2601 no problem. phone is still alive. strange problem with dead set, never happen with that. |
The Following User Says Thank You to mentari For This Useful Post: |
09-01-2008, 14:42 | #13 (permalink) |
Member: 222009 Status: Offline Sonork: 100.1576751 Thanks Meter: 435 | ok fine pls test with huawei 2201 or 2205 and give the result may be problem is only for me !!! |
09-01-2008, 16:26 | #14 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, I don't think that your phone can be dead due to PinFinder due to PinFinder output voltage can not be more that 5v in any case (PinFinder take power from PC USB port). Please, somebody post here more reports with CDMA sets (in fact I never heard before about any damaged CDMA or GSM phones after PinFinder usage). |
09-02-2008, 03:40 | #15 (permalink) |
No Life Poster Join Date: Jul 2006 Location: india Age: 43
Member: 313652 Status: Offline Sonork: 100.1625717 Thanks Meter: 99 | i am having sigmatel s3 set dead after flashing with infinity why |
The Following User Says Thank You to sharpgsm For This Useful Post: |
lg kp 2o2 formting by pinfinder infinity ok | aleem26 | Infinity-Box | 0 | 07-12-2008 17:26 |
Beyond B610 detected by pinfinder | harun_warsanto | Infinity-Box | 5 | 06-27-2008 14:38 |
How can we find 2nd cpu pinout by pinfinder | Maiwand khan | Infinity-Box | 1 | 06-06-2008 11:00 |
Spreadtrum CPU based phone detect pins by pinfinder | Vijendra Saini | Infinity-Box | 1 | 05-08-2008 20:10 |
how ZTE A35 cable detection by pinfinder | green bird | Infinity-Box | 7 | 04-19-2008 18:00 |
