Old 09-21-2008, 12:34   #1 (permalink)
genci titi 2002's Avatar
Member: 193804
Sonork: 100.1684818
Thanks Meter: 1,693
Thumbs up Vodafone227 by zte unlock succes by infinitybox
COM5 [VCP0] selected
Device: ZTE-227, Vodafone-227
Checking data, wait...
Action: unlock
unlock method-1
Boot...
Press and HOLD Power button now (if boot does not start remove/install batery) !
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud...
921600
Set Baud Done
Connecting...
flash: 00EC:257E
Connecting Done
Check hardware...
Check hardware Done
Check parameters...
Check parameters Done
backup critical area...
reading [eeprom-sta]...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-227, Vodafone-227_eeprom-sta_20080921-111022.B1E.bin
loading data...
data loaded
reading [eeprom-sec]...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-227, Vodafone-227_eeprom-sec_20080921-111028.B1E.bin
reading [eeprom-complete]...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-227, Vodafone-227_eeprom-complete_20080921-111030.B1E.bin
reading additional data...
done
backup critical area Done
Check memory...
current status: 0
Check memory Done
Write...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, Remove/Install battery now !
Time used: 26 sec
Unlock instruction:
1. Power-On phone
2. Enter code: 12345678
THANK YOU INFINITYBOX
The Following 3 Users Say Thank You to genci titi 2002 For This Useful Post:
Old 09-21-2008, 14:16   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Thank you very much for test report !
Each test report with attached logs is very important for us so we can see how is Infinity-Box
software works and what is possible problems and successfully done work.
Old 09-22-2008, 00:55   #3 (permalink)
Member: 49720
Thanks Meter: 62
not work i have zte 227 with conter blocker ; plz infinity apdate solution
Old 09-22-2008, 01:19   #4 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
hi sir..
if ur phone counter is blocked, infinty cant unlock it..
j700v unlock succes by ust genci titi 2002 UST Pro II 4 05-12-2010 13:07
B270 is unlocked succefully by UST beneto UST Pro II 3 11-28-2008 22:40
my 411v unlock succed by SMTi lahdache SMTi 0 10-14-2008 21:32
Kp130 Unlock Succes By Infinity genci titi 2002 Infinity-Box 11 07-28-2008 21:06
Z720m unlocked succefully by Easy Unlocker MDK23 Easy-Unlocker 1 11-05-2007 18:45
Page generated in 0.17112 seconds with 9 queries
