07-26-2008, 11:58 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | Kp130 Unlock Succes By Infinity Device: LG-KP130 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 921600 Set baud Done Check flash... current eeprom imei: 352126021219057 file saved: C:\Program Files\InfinityBox\LGA\eeprom_352126021219057_LG-KP130_20080726-124840.B1E.bin ........ version: - Check flash Done Check space... current eeprom imei: 352126021219057 ................................ finalization done Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... write: lock area-1 Write Done Finished, time used: 37 sec Remove/Install battery now ! thank*********infinity box |
The Following User Says Thank You to genci titi 2002 For This Useful Post: |
07-26-2008, 12:28 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @geti Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
07-26-2008, 13:14 | #7 (permalink) |
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | very simply use lg ke 500 keyboard top 1.........18 1: Gnd 2: phone Rx (RJ45 pin-2) 3: phone Tx (RJ45 pin-3) |
07-26-2008, 16:29 | #8 (permalink) |
No Life Poster Join Date: Jun 2003 Age: 53
Member: 30506 Status: Offline Thanks Meter: 81 | COM5 [VCP6] selected Device: LG-KP130 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 921600 Set baud Done Check flash... current eeprom imei: 3521260219****** file saved: D:\Program Files\InfinityBox\LGA\eeprom_3521260219***x_LG-KP130_20080726-182238.B1E.bin .... Check flash Done Check space... current eeprom imei: 3521260219*** ................................ finalization done Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... write: lock area-1 Write Done Finished, time used: 52 sec Remove/Install battery now ! y thank Infinity-Box |
The Following User Says Thank You to nano1 For This Useful Post: |
07-26-2008, 19:14 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
07-28-2008, 17:32 | #11 (permalink) |
Insane Poster Join Date: Sep 2006
Member: 357566 Status: Offline Thanks Meter: 2 | THANKS INFINITY USE KE500 CABLE AND UNLOCK SUCCESSFULY COM5 [VCP0] selected Device: LG-KP130 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 35212602****** file saved: C:\Program Files\InfinityBox\LGA\eeprom_35212602******_LG-KP130_20080728-222854.B1E.bin ........ version: - Check flash Done Check space... current eeprom imei: 35212602******X ................................ finalization done Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... write: lock area-1 Write Done Finished, time used: 51 sec Remove/Install battery now ! |
07-28-2008, 21:06 | #12 (permalink) |
LG KP130 unlocked done by infinity | kingskie | Infinity-Box | 13 | 10-19-2008 19:26 |
Vodafone227 by zte unlock succes by infinitybox | genci titi 2002 | Infinity-Box | 3 | 09-22-2008 01:19 |
lg kp130 unlock ok by Infinity box | aleem26 | LG | 2 | 09-06-2008 11:37 |
KP130 unlock success with infinity ... | mughalG | Infinity-Box | 0 | 05-30-2008 14:57 |
Z720m unlocked succefully by Easy Unlocker | MDK23 | Easy-Unlocker | 1 | 11-05-2007 18:45 |
