03-30-2008, 17:04 | #1 (permalink) |
Freak Poster Join Date: Jul 2003 Location: heaven gate Age: 18
Member: 34710 Status: Offline Thanks Meter: 26 | e101 blocked permanently Device: Alcatel E101 "advanced chip detection" active Action: flash write "smart write" active Write: Firmware Skip: Flex Write: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Write: Eeprom Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection... Check connection done Set baud... 115200 Set baud done Check hardware... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data... reading Alcatel E101_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\backup_Alcatel E101_eeprom_calibration-1_20080330-164253.80E.bin reading Alcatel E101_ffs... file saved: C:\Program Files\InfinityBox\HModule\backup_Alcatel E101_ffs_20080330-164836.80E.bin Read data done Check data... Check data done Writing... Area: Firmware flash: 012A7E2A242A00:54000000000000 Write: Firmware Area: Language Pack flash: 012A7E2A242A00:54000000000000 Write: Language Pack Area: Eeprom flash: 012A7E2A242A00:54000000000000 Write: Eeprom Writing done Finished, time used: 917 sec Remove/Install battery now ! |
03-30-2008, 19:23 | #4 (permalink) |
Member: 34710 Status: Offline Thanks Meter: 26 | Good team with daily updates,i just downloaded latest update *H module v1.11 leleased today and has solved my problem.this is logCOM4 [VCP0] selected Device: Alcatel E101 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection... Check connection done Set baud... 115200 Set baud done Check hardware... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data... reading Alcatel E101_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\backup_Alcatel E101_eeprom_calibration-1_20080330-190500.80E.bin Read data done Check data... Check data done Writing... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Writing done Finished, time used: 90 sec Remove/Install battery now !.thanx |
03-31-2008, 21:56 | #6 (permalink) |
Freak Poster Join Date: May 2004 Location: Macedonia Age: 54
Member: 65593 Status: Offline Thanks Meter: 17 | I have a two pieces alcatel 101. The first going everithing ok but when I put sim the phone say MEPO NOT PRESENT The second going everthing ok and unlock it succesfull. I have problem with the first .... I work with infinity box the latest version... h module1.11 Please how to solve the problem! best regards |
04-01-2008, 09:30 | #8 (permalink) |
Member: 65593 Status: Offline Thanks Meter: 17 | My fault is .beacouse I dont chek before to do unlock.Just connect the phone to infinity box and do unlock function.The aplication ask me to save eeprom I do yes and unlock function going to do. here to log file: ==== log opened: [3/31/2008 10:29:42 PM] ==== Application: C:\Program Files\InfinityBox\HModule\HModule.exe Loading data, wait... [Infinity Box] v1.11 S/N: Wait... Current model: Alcatel E101 Done COM6 [VCP0] selected Device: Alcatel E101 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection... Check connection done Set baud... 115200 Set baud done Check hardware... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data... reading Alcatel E101_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\backup_Alcatel E101_eeprom_calibration-1_20080331-223225.80E.bin Read data done Check data... Check data done Writing... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Writing done Finished, time used: 76 sec Remove/Install battery now ! |
04-01-2008, 12:34 | #9 (permalink) |
No Life Poster Join Date: Nov 2006 Location: INDIA(GUJRAT,RAJKOT) Age: 37
Member: 397884 Status: Offline Sonork: 100.1587035 Thanks Meter: 168 | sir alcatel after unlock dead how i repair this COM5 [VCP0] selected Device: Alcatel E101 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection... Check connection done Set baud... 115200 Set baud done Check hardware... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data... reading Alcatel E101_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\backup_Alcatel E101_eeprom_calibration-1_20080401-162541.80E.bin Read data done Check data... Check data done Writing... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Writing done Finished, time used: 77 sec Remove/Install battery now ! |
04-01-2008, 15:51 | #11 (permalink) |
Member: 397884 Status: Offline Sonork: 100.1587035 Thanks Meter: 168 | firstly sory for using word "repair"first phone is lock and after unlock phone is dead and now software can't detect phone sir... |
04-01-2008, 16:01 | #12 (permalink) | |
If phone can't be connected this means that: 1. battery is empty 2. cable is wrong or damaged 3. phone hardware is damaged Please, check each step very carefully, especially first one. | |
04-01-2008, 16:24 | #13 (permalink) |
Member: 397884 Status: Offline Sonork: 100.1587035 Thanks Meter: 168 | sir 1 battry's valtage 3.8v 2 cable same as first it is in good condition 3 phone is brand new sir rx =1.7v tx=1.8v sir i chack all thing and now software cant detect phone box green light is continusly glowing |
Alcatel E101 " permanently blocked " any solution? | kungpaoski | Infinity-Box | 6 | 04-29-2008 09:04 |
please e101 blocked permanently | karikari | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 1 | 04-26-2008 17:57 |
Trium "blocked permanent" solution | GSM Brothers | Mitsubishi | 6 | 04-07-2006 13:19 |
TCD128/BC 'u' Blocked Permanantly | anduin | Philips | 9 | 02-05-2003 17:00 |
