Old 04-20-2008, 17:39   #1 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Spice S700 After complete Format FFS display is BLACK .
Hello to all ,
Today i got dead S700 model.
First I connect the phone to the Infinity box. & read full flash.
And after all i format the phone with safe mode. . . . . But phone can't power on.
Then I select the complete Format FFS. After complete format phone will be on but only black display show (I mean disply can't show No LED NO picture) & blue light are continues blink.
Any suggestion what is the matter & where is the problem . . . .
Thankx in advance Infinity team.
Old 04-20-2008, 20:44   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
i think it is time to use flash file from our support site
Old 04-21-2008, 06:47   #3 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Here is the software info of that model
ver. sw1: ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7311IN00-001-R1F.BIN
ver. sw2: 7S7311IN00-001-R1F, 00000000
In support ara only one version avaible.
Flash the phone with this version . . . . . .?
Old 04-21-2008, 09:37   #4 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
I have download this file from support area.
Spice-S700_ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S-7311-IN00-001-R1E_0608_V82_2007-06-12_En.B0M
& select this file & flash the phone here is the flash LOG . . .
COM9 [VCP0] selected
Device: Spice S700
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
chip: 0031:7341:A05C
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 98004900000002:29EA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
Initialize Done
Set baud...
921600
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S-7311-IN00-001-R1E.BIN
ver. sw2: 7S-7311-IN00-001-R1E, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading [eeprom[ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S-7311-IN00-001-R1E.BIN]]...
file saved: C:\Program Files\InfinityBox\MModule\backup_eeprom[ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S-7311-IN00-001-R1E.BIN]_20080421-113742.B0E.bin
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Area: Firmware
Write: Firmware
Write Done
Finalization...
Finalization Done
Finished, time used: 218 sec
Remove/Install battery now !
After flash the phone problem of black display is not solve.
Old 04-21-2008, 09:57   #5 (permalink)
Member: 148515
hello!
time to try repair eeprom
Old 04-21-2008, 11:54   #6 (permalink)
GSMSERVE's Avatar
Member: 80990
Sonork: 100.1583974
Thanks Meter: 312
Write repair_eeprom , format FFs and write imei.
Old 04-21-2008, 16:58   #7 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Dear ,
I think no need to change to IMEI. Cause IMEI is OK of this phone.
after flash n73 display is black dssmobile Universalbox 10 05-29-2009 04:19
Ztc a898 shows only charging after complete format bhogpurmail Infinity-Box 4 05-26-2009 22:27
Spice S700 After Full format Habg on WELCOME & goes Off....... amol_sm Infinity-Box 3 07-30-2008 13:14
after also format ffs phone restart with sim EMOTION BBSR Infinity-Box 5 02-17-2008 13:25
anycool no network after complete format ffs sezief Infinity-Box 16 02-10-2008 13:30
Page generated in 0.19224 seconds with 9 queries
