01-11-2011, 23:29 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: Trusted Source
Member: 1175556 Status: Offline Thanks Meter: 251 | unlock gtx-212??? Claro have some method for unlock it but it has "invalid imei". we dont have 0 phones for test but I´ll have soon. please update!! best regards |
01-12-2011, 14:33 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, We need to get some information about phone hardware: 1. What is this phone CPU chip name ? 2. What is phone bottom connector type, how many pins ? Please, post an answer here or send an information to [email protected] Thank you very much in advance for information about this phone ! |
01-12-2011, 19:49 | #3 (permalink) |
Member: 1175556 Status: Offline Thanks Meter: 251 | ok, get me some days for upload these information, and we need the update but not in undertest..we need full unlock witout imei invalid, if you can´t unlockit dont update. or you can sendme mmodule beta for test after I´ll sent you the information. |
02-12-2011, 00:45 | #5 (permalink) | |
We need to get some information about phone hardware: 1. What is this phone CPU chip name ? 2. What is phone bottom connector type, how many pins ? Please, post an answer here or send an information to [email protected] Thank you very much in advance for information about this phone ! | |
06-16-2011, 16:08 | #6 (permalink) |
No Life Poster Join Date: Jan 2005 Location: Land of Lakes and Volcanoes Age: 51
Member: 111014 Status: Offline Thanks Meter: 132 | Here is information UTSTARCOM GTX212 Action: read/check information Model: UTStarcom-GPF198 Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: AT+ESLP=0 Software version: MT6223, E05" Software date: CELLONSZ23 Barcode: C1012_4.3_0x01208_CLARO_CA_NUMONYX imei-1: 2000.00.00" imei-2: 18ED11010260511 imei-3: 354689040152037 Finished, time used: 11 sec Remove/Install battery now ! CABLE IS SFR 341 |
06-18-2011, 23:17 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Sorry for delay, but I hope you understand that it's not so easy to support new models without having sample phones on hands. We can support new models without sample units just because we have a brilliant programmers who can think in 5D. Download MModule v3.93 from "main" support area and try to unlock your phone. Also, pls, post here this phone pinout. |
06-20-2011, 15:38 | #12 (permalink) |
Member: 111014 Status: Offline Thanks Meter: 132 | Here is first unlocked phone COM18 [VCP0] selected module v3.93 Action: read unlock codes unlock method: read codes Model: UTStarcom-GTX212 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:4477:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: C1012_4.9_0x01209_CLARO_NI_NUMONYX Version: CELLONSZ23C_09A_GEMINI_HW ==================== New firmware found (v.3.93, database date: 29.05.2011): C1012_4.9_0x01209_CLARO_NI_NUMONYX This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== 86 byte(s) read imei: 35468904210725 connection Ok 193 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 181 byte(s) read reading data... 972 byte(s) read lock[1] code: + 74985322 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if phone do not ask for a code try: *983*8284# if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone (do not remove battery) - read unlock codes - restore original imei Finished, time used: 4 min 49 sec Remove/Install battery now ! You are the best !!!!!!!!!!!!!!! Pinout are the same for other utstarcom like 1138 Thanks boss !! |
The Following User Says Thank You to nicacel For This Useful Post: |
06-22-2011, 00:15 | #13 (permalink) | |
Insane Poster Join Date: Sep 2009 Location: Nicaragua
Member: 1115310 Status: Offline Sonork: negacell Thanks Meter: 10 | Quote:
06-22-2011, 18:26 | #15 (permalink) |
Member: 1115310 Status: Offline Sonork: negacell Thanks Meter: 10 | ==== [21/06/2011 04:51:10 p.m.] ==== COM6 [VCP0] selected module v3.95 Action: read unlock codes unlock method: read codes Model: UTStarcom-GTX212 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:6779:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E08 Date: 2000.00.00 Version: 1.0 Version: C1012_4.4_0x01208_CLARO_CA_NUMONYX Version: CELLONSZ23C_09A_GEMINI_HW ==================== New firmware found (v.3.95, database date: 20.06.2011): C1012_4.4_0x01208_CLARO_CA_NUMONYX This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== 86 byte(s) read imei: 35468904106138 connection Ok 193 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 181 byte(s) read reading data... 972 byte(s) read lock[1] code: + 84794315 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if phone do not ask for a code try: *983*8284# if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone (do not remove battery) - read unlock codes - restore original imei Finished, time used: 22 sec Remove/Install battery now ! i can read the unlock code, but when I put a sim card from another operator just says sim blocked, where I can get the flash eeprom |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
