06-14-2019, 16:44 | #1 (permalink) |
Freak Poster Join Date: Oct 2012 Location: IRAN.IR ----عل
Member: 1824614 Status: Offline Sonork: ali_f*******[email protected] Thanks Meter: 112 | Error : Fail to init protocol! INFO : PRELOADER Level : Connect device in BROM mode! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM6) MODE : PRELOADER PORT PORT : 6 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000001 BROM : SecMode : SBC BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00002001 : DA SEND ERROR! ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE! INFO : PRELOADER Level : Connect device in BROM mode! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM6) MODE : PRELOADER PORT PORT : 6 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000001 BROM : SecMode : SBC BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00002001 : DA SEND ERROR! ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE! INFO : PRELOADER Level : Connect device in BROM mode! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
06-18-2019, 13:33 | #3 (permalink) |
Member: 1824614 Status: Offline Sonork: ali_f*******[email protected] Thanks Meter: 112 | Card found : 73FD734E , v0137 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.06 Load IDBase v123080 Ok! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM55) MODE : PRELOADER PORT PORT : 55 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000001 BROM : SecMode : SBC BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00002001 : DA SEND ERROR! ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE! INFO : PRELOADER Level : Connect device in BROM mode! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
06-18-2019, 14:11 | #4 (permalink) | |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | Quote:
hold both keys and connect it | |
The Following User Says Thank You to kamal_singla For This Useful Post: |
06-23-2019, 07:03 | #5 (permalink) |
Member: 1824614 Status: Offline Sonork: ali_f*******[email protected] Thanks Meter: 112 | BROM : 0x00002001 : DA SEND ERROR! ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE! INFO : PRELOADER Level : Connect device in BROM mode! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Scanning devices ...1 found dev[1] 0123456789ABCDEF Mode: normal Hardware: mt6735 Manufactory: SMART Model: ADVANCE PRO Checking environment ... System Info Display ID: NRD90M System Ver: 7.0 REL API Level: 24 Incremental: 1512379296 Model: Advance Pro Brand: SMART Device: Advance_Pro Platform: mt6737m Product: Advance_Pro Language: Rigion: IR SDCard Info No sdcard detected Device Info Serial number: 0123456789ABCDEF Hardware: mt6735 Bootmode: normal Bootloader ver: unknown Revision: 0 Main version: Baseband ver: unknown GSM baseband: MOLY.LR9.W1444.MD.LWTG.MP.V110.5.P95, 2017/11/28 15:39 GSM sim state: ABSENT,ABSENT Get Bluetooth info failed WI-FI is disabled Root Access: No root Get device information done , time used 7.18s Time used : 7.2 s |
06-23-2019, 12:47 | #7 (permalink) |
Member: 1824614 Status: Offline Sonork: ali_f*******[email protected] Thanks Meter: 112 | Hello Will not boot Error |
06-23-2019, 14:38 | #9 (permalink) |
Member: 1824614 Status: Offline Sonork: ali_f*******[email protected] Thanks Meter: 112 | All Done By EFT Dongle Wating Device..........OK CPU: MT6737M Chip Version: 0x0000ca00 Chip Ext Clock: EXT_26M Writing Mode..... Wating Device..........OK Internal RAM: Internal SRAM Size: 128.00 KB External RAM: Type DRAM External Ram Size: 1.00 GB EMMC: EMMC PART BOOT1 Size: 4.00 MB EMMC PART BOOT2 Size: 4.00 MB EMMC PART RPMB Size: 4.00 MB EMMC PART USER Size: 14.56 GB Battery: Battery Voltage: 3879 Injection..........OK Detecting Parts info............OK [ID: 1] [preloader] BaseAddr(0x00000000) Size(0x00400000) [ID: 8] [pgpt] BaseAddr(0x00000000) Size(0x00080000) [ID: 8] [proinfo] BaseAddr(0x00080000) Size(0x00300000) [ID: 8] [nvram] BaseAddr(0x00380000) Size(0x00500000) [ID: 8] [protect1] BaseAddr(0x00880000) Size(0x00a00000) [ID: 8] [protect2] BaseAddr(0x01280000) Size(0x00a00000) [ID: 8] [lk] BaseAddr(0x01c80000) Size(0x00080000) [ID: 8] [para] BaseAddr(0x01d00000) Size(0x00080000) [ID: 8] [boot] BaseAddr(0x01d80000) Size(0x01000000) [ID: 8] [recovery] BaseAddr(0x02d80000) Size(0x01000000) [ID: 8] [logo] BaseAddr(0x03d80000) Size(0x00800000) [ID: 8] [expdb] BaseAddr(0x04580000) Size(0x00a00000) [ID: 8] [seccfg] BaseAddr(0x04f80000) Size(0x00080000) [ID: 8] [oemkeystore] BaseAddr(0x05000000) Size(0x00200000) [ID: 8] [secro] BaseAddr(0x05200000) Size(0x00600000) [ID: 8] [keystore] BaseAddr(0x05800000) Size(0x00800000) [ID: 8] [tee1] BaseAddr(0x06000000) Size(0x00500000) [ID: 8] [tee2] BaseAddr(0x06500000) Size(0x00500000) [ID: 8] [frp] BaseAddr(0x06a00000) Size(0x00100000) [ID: 8] [nvdata] BaseAddr(0x06b00000) Size(0x02000000) [ID: 8] [metadata] BaseAddr(0x08b00000) Size(0x02500000) [ID: 8] [system] BaseAddr(0x0b000000) Size(0xc0000000) [ID: 8] [cache] BaseAddr(0xcb000000) Size(0x19000000) [ID: 8] [userdata] BaseAddr(0xe4000000) Size(0x2bed80000) [ID: 8] [flashinfo] BaseAddr(0x3a2d80000) Size(0x01000000) [ID: 8] [sgpt] BaseAddr(0x3a3d80000) Size(0x00080000) Detecting Device info.......OK Product: SMART Device Model: Advance Pro ID: alps-mp-n0.mp1-V1.0.2_tinno6737m.35.n_P243 Sw Internal: Build Date: Mon Dec 4 17:21:05 CST 2017 Chip Ver: S01 Android Version: 7.0 Architecture: armeabi-v7a All Done By EFT Dongle |
06-23-2019, 14:43 | #10 (permalink) |
Member: 1824614 Status: Offline Sonork: ali_f*******[email protected] Thanks Meter: 112 | CPU: MT6737M Chip Version: 0x0000ca00 Chip Ext Clock: EXT_26M Writing Mode..... Wating Device..........OK Internal RAM: Internal SRAM Size: 128.00 KB External RAM: Type DRAM External Ram Size: 1.00 GB EMMC: EMMC PART BOOT1 Size: 4.00 MB EMMC PART BOOT2 Size: 4.00 MB EMMC PART RPMB Size: 4.00 MB EMMC PART USER Size: 14.56 GB |
06-23-2019, 14:46 | #11 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | My dear "friend", you have one hour to remove your useless posts. I checked your posts history and found it seems as special advertizing, and ignoring support help at all. So, if you NOT stop it now - you will be banned forever. Time started. |
06-23-2019, 15:04 | #12 (permalink) |
Member: 1824614 Status: Offline Sonork: ali_f*******[email protected] Thanks Meter: 112 | Cpu: Mt6737m Cpu: Mt6737m cpu: Mt6737m |
06-23-2019, 15:06 | #13 (permalink) |
Member: 1824614 Status: Offline Sonork: ali_f*******[email protected] Thanks Meter: 112 | Wating Device..........OK CPU: MT6737M Chip Version: 0x0000ca00 Chip Ext Clock: EXT_26M Writing Mode..... Wating Device..........OK Internal RAM: Internal SRAM Size: 128.00 KB External RAM: Type DRAM External Ram Size: 1.00 GB EMMC: EMMC PART BOOT1 Size: 4.00 MB EMMC PART BOOT2 Size: 4.00 MB EMMC PART RPMB Size: 4.00 MB EMMC PART USER Size: 14.56 GB Battery: Battery Voltage: 3879 Injection..........OK Detecting Parts info............OK [ID: 1] [preloader] BaseAddr(0x00000000) Size(0x00400000) [ID: 8] [pgpt] BaseAddr(0x00000000) Size(0x00080000) [ID: 8] [proinfo] BaseAddr(0x00080000) Size(0x00300000) [ID: 8] [nvram] BaseAddr(0x00380000) Size(0x00500000) [ID: 8] [protect1] BaseAddr(0x00880000) Size(0x00a00000) [ID: 8] [protect2] BaseAddr(0x01280000) Size(0x00a00000) [ID: 8] [lk] BaseAddr(0x01c80000) Size(0x00080000) [ID: 8] [para] BaseAddr(0x01d00000) Size(0x00080000) [ID: 8] [boot] BaseAddr(0x01d80000) Size(0x01000000) [ID: 8] [recovery] BaseAddr(0x02d80000) Size(0x01000000) [ID: 8] [logo] BaseAddr(0x03d80000) Size(0x00800000) [ID: 8] [expdb] BaseAddr(0x04580000) Size(0x00a00000) [ID: 8] [seccfg] BaseAddr(0x04f80000) Size(0x00080000) [ID: 8] [oemkeystore] BaseAddr(0x05000000) Size(0x00200000) [ID: 8] [secro] BaseAddr(0x05200000) Size(0x00600000) [ID: 8] [keystore] BaseAddr(0x05800000) Size(0x00800000) [ID: 8] [tee1] BaseAddr(0x06000000) Size(0x00500000) [ID: 8] [tee2] BaseAddr(0x06500000) Size(0x00500000) [ID: 8] [frp] BaseAddr(0x06a00000) Size(0x00100000) [ID: 8] [nvdata] BaseAddr(0x06b00000) Size(0x02000000) [ID: 8] [metadata] BaseAddr(0x08b00000) Size(0x02500000) [ID: 8] [system] BaseAddr(0x0b000000) Size(0xc0000000) [ID: 8] [cache] BaseAddr(0xcb000000) Size(0x19000000) [ID: 8] [userdata] BaseAddr(0xe4000000) Size(0x2bed80000) [ID: 8] [flashinfo] BaseAddr(0x3a2d80000) Size(0x01000000) [ID: 8] [sgpt] BaseAddr(0x3a3d80000) Size(0x00080000) Detecting Device info.......OK Product: SMART Device Model: Advance Pro ID: alps-mp-n0.mp1-V1.0.2_tinno6737m.35.n_P243 Sw Internal: Build Date: Mon Dec 4 17:21:05 CST 2017 Chip Ver: S01 Android Version: 7.0 Architecture: armeabi-v7a All Done By EFT Dongle[/QUOTE] |
06-23-2019, 23:31 | #14 (permalink) | |
No Life Poster Join Date: Jan 2016 Location: Gsm flashing
Member: 2521913 Status: Offline Thanks Meter: 251 | Quote:
Why are you so stupid? | |
06-24-2019, 00:13 | #15 (permalink) | |
No Life Poster Join Date: Feb 2018 Location: Nigeria
Member: 2812901 Status: Offline Thanks Meter: 493 | Quote:
Try to remove this post or make apologies from infinity-team, otherwise you'll be banned forever. http://forum.gsmhosting.com/vbb/misc.php?do=showrules | |
