01-30-2020, 03:42 | #1 (permalink) |
Registered User Join Date: Apr 2015 Location: Cuba
Member: 2381725 Status: Offline Thanks Meter: 126 | Error to flash ZTE Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.07 Load IDBase v124106 Ok! Preloader [HW DEV] Info : EMI : DEV : MT6752 EMI : SRC : preloader_v200f.bin EMI : CNT : 0002 EMI : [00] : eMMC : DDR3 : ID : 90014A483847316505 : VEN : HYNIX | DEV : H8G1e : RAM : [ 1.00 GB ] EMI : [01] : eMMC : DDR3 : ID : 150100513732534D42 : VEN : SAMSUNG | DEV : Q72SMB : RAM : [ 1.00 GB ] Operation : Write Flash [ v2.07 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Disabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :11 [FL] : Set : preloader_V200F.bin [FL] : Set : lk-sign.bin [FL] : Set : boot-sign.img [FL] : Set : recovery-sign.img [FL] : Set : logo-sign.bin [FL] : Set : secro-sign.img [FL] : Set : trustzone-sign.bin [FL] : Set : trustzone-sign.bin [FL] : Set : system-sign.img [FL] : Set : cache-sign.img [FL] : Set : userdata-sign.img [FL] : Total size : 0x7BC19228 [ 1.93 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... Device not found! Check cable, battery, connection and drivers! Reconnect Power/Cable! Operation : Write Flash [ v2.07 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :11 [FL] : Set : preloader_V200F.bin [FL] : Set : lk-sign.bin [FL] : Set : boot-sign.img [FL] : Set : recovery-sign.img [FL] : Set : logo-sign.bin [FL] : Set : secro-sign.img [FL] : Set : trustzone-sign.bin [FL] : Set : trustzone-sign.bin [FL] : Set : system-sign.img [FL] : Set : cache-sign.img [FL] : Set : userdata-sign.img [FL] : Total size : 0x7BC19228 [ 1.93 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM452) MODE : BOOTROM PORT : 452 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Enabled BROM : SLA BROM : SLA Passed! BROM : SLA CHLNG not used Fail to disable Dog! AGENT : Look for suitable BootChain in DA ... AGENT : younis.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DA : DRAM NOT SUPPORT NAND : 000000000000000000000000 eMMC : OK eMMC : 90014A483847316505074FA15C190699 DAInf: 4 : 2 : 147 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 484A019065314738A14F07059906195C NAND : DA : DRAM NOT SUPPORT NAND : 000000000000000000000000 EMI : DEV : MT6752 EMI : SRC : preloader_v200f.bin EMI : CNT : 0002 EMI : [00] : ID : 90014A483847316505 : VEN : HYNIX | DEV : H8G1e : RAM : [ 1.00 GB ] EMI : [01] : ID : 150100513732534D42 : VEN : SAMSUNG | DEV : Q72SMB : RAM : [ 1.00 GB ] EMI : Init EMI from PRELOADER INIT : 0xBC : DRAM [ 0x00000000 : [ 0 B ] ] DRAM : DRAM: 0x40000000 [ 1.00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A48384731655074FA15C197299 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G1e EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 58EE30C7604599791CD5C1ED9FF1DF9F STATUS : DA : NOR OTP GETSIZE FAIL BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM453) MODE : PRELOADER PORT PORT : 453 Boot done! [FL] : HW verification passed! SEC_DL : True (CUST) SEC_DL : SECURE USB DL ENABLED SEC_ID : 0x61356166663732376362303431633663 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000000080000 Erase : 0x0000000001C80000 : 0x0000000004D80000 ERR : 0xC0010002 ERR : ABORT ERR : 0x00000000|0x00000000 Error : Flashing failed! Seems as something wrong with device! Check battery charge and device state! Reconnect Power/Cable! Operation : Identify [ v2.07 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM452) MODE : BOOTROM PORT : 452 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Enabled BROM : SLA BROM : SLA Passed! BROM : SLA CHLNG not used Fail to disable Dog! AGENT : Look for suitable BootChain in DA ... AGENT : younis.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DA : DRAM NOT SUPPORT NAND : 000000000000000000000000 eMMC : OK eMMC : 90014A483847316505074FA15C190699 DAInf: 4 : 2 : 147 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 484A019065314738A14F07059906195C NAND : DA : DRAM NOT SUPPORT NAND : 000000000000000000000000 EMI : DEV : MT6752 EMI : SRC : preloader_v200f.bin EMI : CNT : 0002 EMI : [00] : ID : 90014A483847316505 : VEN : HYNIX | DEV : H8G1e : RAM : [ 1.00 GB ] EMI : [01] : ID : 150100513732534D42 : VEN : SAMSUNG | DEV : Q72SMB : RAM : [ 1.00 GB ] EMI : Init EMI from PRELOADER INIT : 0xBC : DRAM [ 0x00000000 : [ 0 B ] ] DRAM : DRAM: 0x40000000 [ 1.00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A48384731655074FA15C197299 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G1e EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 58EE30C7604599791CD5C1ED9FF1DF9F STATUS : DA : NOR OTP GETSIZE FAIL BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM453) MODE : PRELOADER PORT PORT : 453 Boot done! Error : Failed to read initial info! Erased/Damaged or unsupported device??? Seems as something wrong with device! Check battery charge and device state! Reconnect Power/Cable! Operation : Write Flash [ v2.07 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Disabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Enabled Files :11 [FL] : Set : preloader_V200F.bin [FL] : Set : lk-sign.bin [FL] : Set : boot-sign.img [FL] : Set : recovery-sign.img [FL] : Set : logo-sign.bin [FL] : Set : secro-sign.img [FL] : Set : trustzone-sign.bin [FL] : Set : trustzone-sign.bin [FL] : Set : system-sign.img [FL] : Set : cache-sign.img [FL] : Set : userdata-sign.img [FL] : Total size : 0x7BC19228 [ 1.93 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM452) MODE : BOOTROM PORT : 452 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Enabled BROM : SLA BROM : SLA Passed! BROM : SLA CHLNG not used Fail to disable Dog! AGENT : Look for suitable BootChain in DA ... AGENT : younis.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DA : DRAM NOT SUPPORT NAND : 000000000000000000000000 eMMC : OK eMMC : 90014A483847316505074FA15C190699 DAInf: 4 : 2 : 147 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 484A019065314738A14F07059906195C NAND : DA : DRAM NOT SUPPORT NAND : 000000000000000000000000 EMI : DEV : MT6752 EMI : SRC : preloader_v200f.bin EMI : CNT : 0002 EMI : [00] : ID : 90014A483847316505 : VEN : HYNIX | DEV : H8G1e : RAM : [ 1.00 GB ] EMI : [01] : ID : 150100513732534D42 : VEN : SAMSUNG | DEV : Q72SMB : RAM : [ 1.00 GB ] EMI : Init EMI from PRELOADER INIT : 0xBC : DRAM [ 0x00000000 : [ 0 B ] ] DRAM : DRAM: 0x40000000 [ 1.00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A48384731655074FA15C197299 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G1e EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 58EE30C7604599791CD5C1ED9FF1DF9F STATUS : DA : NOR OTP GETSIZE FAIL BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM453) MODE : PRELOADER PORT PORT : 453 Boot done! [FL] : HW verification passed! SEC_DL : True (CUST) SEC_DL : SECURE USB DL ENABLED SEC_ID : 0x61356166663732376362303431633663 [FL] : Pre-Erase [FL] : Whole Flash Erase enabled! Erase : 0x0000000000000000 : 0x00000001D2000000 [FL] : RePartition [FL] : RePartition Ok! SecInit : LK SecInit : BOOT SecInit : RECOVERY SecInit : LOGO SecInit : SECRO SecInit : TEE1 SecInit : TEE2 SecInit : SYSTEM SecInit : CACHE SecInit : USERDATA [FL] : Flashing now ... Write : PRELOADER Update bootloader code ... Update bootloader Ok! Write : LK Write : BOOT Write : RECOVERY Write : LOGO Write : SECRO Write : TEE1 Write : TEE2 Write : SYSTEM ERR : 0xC0050008 ERR : WRITE DATA EXCEPTION ERR : 0x00000000|0x787E074C Error : Flashing failed! Seems as something wrong with device! Check battery charge and device state! Reconnect Power/Cable! |
