Old 12-07-2008, 11:19   #1 (permalink)
Member: 346148
Thanks Meter: 27
error flashing n95 2sim
hi
i can't flash my n95 2sim i always get error
here is the log
eeprom backup enabled, it may takes several minutes !
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031841:6BA0
high speed boot Off
boot packet size: 0002
Release Power button now !
Boot Done
Initialize ...
flash: EC257E25082501:29EA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is damaged, recalculation required
identification#1 detection finished
device-id: E5F45B26
identification#1 protocol ver: 04
ver. sw 1: N618_PCB01_GPRS_MT6227_S01.1.BIN
ver. sw 2: N618.1, 5E636AAE
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: eeprom[N618_PCB01_GPRS_MT6227_S01.1.BIN]...
file saved: E:\Program Files\InfinityBox\ChineseMiracle\eeprom[N618_PCB01_GPRS_MT6227_S01.1.BIN]_20081207-111140.B0E.bin
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
security area (code #1) calculation...
done
detecting security area (code #2)...
security area (code #2) is absent
Area: Firmware
Write: Firmware
error: error# 00000064
error: flash write error: 00012000:00002000
Write Fail
Finished, time used: 244 sec
Remove/Install battery now !
can someone help
best regards
Old 12-07-2008, 12:00   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
It may be hardware problem.
Did you checked phone hardware ?
Probably you need to reball flash chip.
Old 12-07-2008, 20:47   #3 (permalink)
Member: 346148
Thanks Meter: 27
n95 2sim
dear sir
i rehot flah ship and after flashing was ok!!!
phone now power but after logo " nokia nserie "it shut down
so i'm gonna format fs
i 'll post result soon
thanks!
Old 12-08-2008, 00:58   #4 (permalink)
Member: 130995
Hello,
It may be that you need not only rehot but completely reball flash chip (and probably CPU too) because if it was bad contact you need to check hardware more detailed.
error flash N95 - N95 8gb's - product selection mismatch LauAlf HWK 13 01-10-2012 11:43
flashing N95 2sim problem zetta Infinity-Box 4 11-27-2008 21:05
error flashing n95 jham Universalbox 5 07-09-2008 00:05
Error flashing N95 leive Universalbox 1 05-06-2008 15:54
Error Flashing N95 fonetech MT-BOX 6 02-01-2008 14:19
Page generated in 0.15788 seconds with 9 queries
