08-19-2011, 15:57 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: mt brazil
Member: 211017 Status: Offline Thanks Meter: 312 | Error read phone imei 1357902... Action: read/check information Model: _Autodetect MT6228-6268 NAND Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6252" Hardware version: BESTONE52_10A_6432_HW Software version: Q5_N_51_EFSP_V4.0.2" Software date: 2000.00.00 Barcode: AT+EGMR=0,5 Finished, time used: 9 sec Remove/Install battery now ! COM3 [VCP0] selected module v4.00 Device: _Autodetect MT6253 NOR Checking data, wait... Action: read flash NAND interface: BROM_DLL_v3.1044.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6250:CA00:8A00 status: FF bbchip bl ver: FE NOR flash id[0000]: 0000:000000000000 [AMD] AM29DL323D chip size: 0Mb otp status/size: S_DONE/00000000 NAND flash id[0000]: 0000:000000000000 [SAMSUNG] K9F5608Q0C chip size: 0Mb page/spare size: 0000/0000 pages per block: 0000 bits i/o: 00 address cycles: 00 internal RAM size: 00000000 external RAM [HW_RAM_UNKNOWN, CS0] size: 00000000 error: can not boot device: 0C09:S_DA_UNSUPPORTED_BBCHIP error: last error: 0C09:S_DA_UNSUPPORTED_BBCHIP Disconnect... done Finished, time used: 19 sec Remove/Install battery now ! COM3 [VCP0] selected module v4.00 Device: _Autodetect MT6228-6268 NAND Checking data, wait... Action: read flash NAND interface: BROM_DLL_v3.1044.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6250:CA00:8A00 status: FF bbchip bl ver: FE NOR flash id[0000]: 0000:000000000000 [AMD] AM29DL323D chip size: 0Mb otp status/size: S_DONE/00000000 NAND flash id[0000]: 0000:000000000000 [SAMSUNG] K9F5608Q0C chip size: 0Mb page/spare size: 0000/0000 pages per block: 0000 bits i/o: 00 address cycles: 00 internal RAM size: 00000000 external RAM [HW_RAM_UNKNOWN, CS0] size: 00000000 error: can not boot device: 0C09:S_DA_UNSUPPORTED_BBCHIP error: last error: 0C09:S_DA_UNSUPPORTED_BBCHIP Disconnect... done Finished, time used: 17 sec Remove/Install battery now ! but imei write correct: Action: "repair imei" Model: _Autodetect MT6228-6268 NAND Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-1: 135790246811220 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei-1: 35528902XXXXX55 verification Ok Finished, time used: 6 sec Remove/Install battery now ! Action: "repair imei" Model: _Autodetect MT6228-6268 NAND Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-2: 135790246811220 imei write method: mode-1 imei write channel: imei #2 for dual sim/mono CPU new imei-2: 35528902XXXXX63 verification Ok Finished, time used: 5 sec Remove/Install battery now ! |
08-22-2011, 16:31 | #4 (permalink) |
Member: 211017 Status: Offline Thanks Meter: 312 | i have other phone with 4 imei phone restart, Format work phone but 4 imei 135.... imei 1 and 2 write perfect but 3 imei same error COM3 [VCP0] selected module v4.01 Device: _Autodetect MT6253 NOR Checking data, wait... advanced flash detection disabled Action: "repair imei" imei write method: mode-3 imei write channel: imei #3 for triple sim CPU new imei: 355200110xxxx94 ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6253:8A04:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 29 sec Remove/Install battery now ! I try in all speed |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
