Old 02-18-2009, 19:03   #1 (permalink)
Member: 241452
Thanks Meter: 36
Dongle big problem
i infinity team, i discovered that my box usb service port is not working when insert cable therefor, i cannot connect pinfider to infinity box likewise the port cannot be used for any operation need ur help plsssssssssssssss:co nfused::co nfused:
Old 02-18-2009, 19:09   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
What was happened that box stop to work ?
Old 02-18-2009, 20:05   #3 (permalink)
Member: 241452
Thanks Meter: 36
i was tryin to flash NKTEL C5000 TRU pinout then it apair on my system power surge that all need ur help plssssssssssssssssssssssssssssss
Old 02-18-2009, 20:31   #4 (permalink)
Member: 130995
Hello,
You need to buy and replace FT232 chip inside box.
Make "search" in this forum regarding "FT232" and you will see detailed information.
Old 02-28-2009, 09:14   #5 (permalink)
Member: 241452
Thanks Meter: 36
dongle back alive after changing ft232 from usb-smart cable thanksssssssssss soooooooooooooooo much
Old 02-28-2009, 09:56   #6 (permalink)
Member: 295357
Thanks Meter: 15
plz solve problem this
----------Process started: 1:55:49 PM----------
Locating server...
Server address found#1
Connecting to server#1...
Server connection successfully established
S/N: ********, Firmware: 0112.02
Authenticating on server...
Authentication stage error: Server reported error:[0007] No more upgrade logs: Dongle is up-to-date and has latest firmware. Don't try more !
If software can not start (or SmartCard data is damaged) contact to [email protected]
Old 02-28-2009, 10:01   #7 (permalink)
Member: 128745
Thanks Meter: 16,936
Locating server...
Please send the above information to [email protected]
you will get answer with repair instructions
Old 02-28-2009, 10:20   #8 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
Locating server...
read these lines carefully and explain what problem r u facing
The Following User Says Thank You to deepakgarg For This Useful Post:
Old 02-28-2009, 16:46   #9 (permalink)
Member: 295357
Thanks Meter: 15
my problem is that pinfinder set not detect show this error
software version: 1.17
cable type: 1x18 (L18B)
platform: MT: MT6205, MT6217-MT6228, MT6230
searching adapter at COM4...
adapter found, version: 2000
pins: 18, plain
power cycles: 1
activation cycles: 7
power-off delay: 20
start Rx/Tx: 1/1
Loading configuration...
Initializing...
Press and HOLD phone Power button now !
detecting pins...
failed to detect pins
time required: 135 sec
Power Off !
Set parameter to value 20 (or more) and repeat operation (parameter "Finder activation tries")
Old 02-28-2009, 16:57   #10 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
pins: 18, plain
power cycles: 1
power-off delay: 20
start Rx/Tx: 1/1
Initializing...
detecting pins...
Power Off !
what cpu your phone has????also read carefully page 20 in pinfinder manual
Old 02-28-2009, 18:58   #11 (permalink)
Member: 130995
pins: 18, plain
power cycles: 1
power-off delay: 20
start Rx/Tx: 1/1
Initializing...
detecting pins...
Power Off !
Hello,
What is your phone CPU chip name ?
big problem with my mx key sshreesai MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 03-31-2010 10:07
Jaf big problem haytham_84 J.A.F. By Jafsupport.com 0 03-29-2010 20:53
6085 big problem kami1987 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 03-29-2010 13:42
dongle big big big problem?????? sabersabir Easy-Unlocker 8 07-29-2009 22:44
Page generated in 0.22649 seconds with 9 queries
