Old 11-28-2018, 10:39   #16 (permalink)
Registered User
Member: 2462860
Thanks Meter: 71
oh my TP
Originally Posted by JayDi View Post
There is nothing release according this. Will share TP info by requests.
please sir a83 on my hand
TP asap please
Old 11-28-2018, 10:45   #17 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Originally Posted by rebainoor View Post
Yes correct this important to know how SLA challenge work to authorize boot !
Easy, device sends RID and unique data to sign, then wait to signed block back and verify it by public_key.
The Following 3 Users Say Thank You to JayDi For This Useful Post:
Old 11-28-2018, 11:02   #18 (permalink)
JayDi's Avatar
Member: 462970
Not have anything good to make shoot.
Device disassembly require nothing, just remember about need start NOT from screen corner, but after it. Around sccreen corner plastic frame.
After remove screws will void warranty. You had been warned.
Remove battery connector, short TP, insert cable. After device connect - remove short.
The Following 18 Users Say Thank You to JayDi For This Useful Post:
Old 11-28-2018, 11:04   #19 (permalink)
JayDi's Avatar
Member: 462970
BTW - seems as OPPO using/start using EFUSE to avoid downgrade - yes, like QLM! At first look
You can flash older SW preloader, it will enter in brom loop, until new version will not be flashed.
The Following 4 Users Say Thank You to JayDi For This Useful Post:
Old 11-28-2018, 11:12   #20 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 2,107
but it not easy if its easy for what use TP
can you contact me by skype Mr JayDi
Old 11-28-2018, 12:01   #21 (permalink)
dany_boy's Avatar
Member: 1977629
Thanks Meter: 429
(Remove battery connector, short TP, insert cable. After device connect - remove short. )
after device conect need to place battery again to do some opreation for flash or format . ? or its work without battery
Old 11-28-2018, 12:32   #22 (permalink)
mcclinic's Avatar
Member: 593876
Thanks Meter: 302
Without Battery, TP With Battery Always Risky, Maybe can Motherboard Short.
The Following User Says Thank You to mcclinic For This Useful Post:
Old 11-28-2018, 12:42   #23 (permalink)
pshycoboy's Avatar
Member: 1597314
Thanks Meter: 116
and now how to boot this phone without TP ?
Old 11-28-2018, 12:54   #24 (permalink)
bronce's Avatar
Member: 488875
Sonork: 100.1626294
Thanks Meter: 1,129
can you PLS. share/give me TP info pls...
tia,
Old 11-28-2018, 13:29   #25 (permalink)
JayDi's Avatar
Member: 462970
tia,
Every TP procedure is potentially dangerous.
So better not use, or use at own risk. Also, better use some resistor for better short circuit protection.
The Following 2 Users Say Thank You to JayDi For This Useful Post:
Old 11-28-2018, 13:29   #26 (permalink)
babarmughal's Avatar
Member: 2609063
Thanks Meter: 103
Load IDBase v111571 Ok!
Update configuration ...
Update Ok!
Load IDBase v112373 Ok!
Operation : Identify [ v2.02 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : DA USB VCOM Port (COM12)
MODE : PRELOADER PORT
PORT : 12
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
     CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001
     TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x00000005
BROM : SecMode  : SBC+SDA
BROM : PRELOADER PORT
MODE : Oppo : F5 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : DA_PL_CRYPTO.bin
AGENT : Found MT6763
AGENT : MTK_DOWNLOAD_AGENT
     BROM : Sending 1st DA ...
  BROM  : 0x00002001 : DA SEND ERROR!
  ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE!
  INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO
Error : Fail to init protocol!
Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
Reconnect Power/Cable!
PTFN : MediaTek USB Port (COM6)
MODE : BOOTROM
PORT : 6
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
BROM : SecLevel : 0x000000E5
BROM : SecMode  : SBC+SDA+SEL
BROM : BOOTROM
BROM : SLA
BROM : SLA Passed!
BROM : DA sent
BROM :Transfer control to DA ...
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
DA : EXT_RAM NOT initialized!
     EMI : DEV : MT6763
     EMI : SRC : preloader_oppo6763_17031.bin
     EMI : CNT : 000F
     EMI : [00] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN   | DEV :  : RAM : [ 0 B ]
     EMI : [01] : eMCP : eMMC+LP/DDR4 , ID : 150100444836444D42 : VEN : SAMSUNG   | DEV : DH6DMB : RAM : [ 4,00 GB ]
     EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100525836344D42 : VEN : SAMSUNG   | DEV : RX64MB : RAM : [ 4,00 GB ]
     EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344142 : VEN : SAMSUNG   | DEV : RH64AB : RAM : [ 4,00 GB ]
     EMI : [04] : eMCP : eMMC+LP/DDR4 , ID : 150100334836434D42 : VEN : SAMSUNG   | DEV : 3H6CMB : RAM : [ 6,00 GB ]
     EMI : [05] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344D42 : VEN : SAMSUNG   | DEV : RH64MB : RAM : [ 4,00 GB ]
     EMI : [06] : eMCP : eMMC+LP/DDR3 , ID : 150100474436424D42 : VEN : SAMSUNG   | DEV : GD6BMB : RAM : [ 3,00 GB ]
     EMI : [07] : eMCP : eMMC+LP/DDR3 , ID : 150100475836424D42 : VEN : SAMSUNG   | DEV : GX6BMB : RAM : [ 3,00 GB ]
     EMI : [08] : eMCP : eMMC+LP/DDR3 , ID : 150100474536424D42 : VEN : SAMSUNG   | DEV : GE6BMB : RAM : [ 3,00 GB ]
     EMI : [09] : eMCP : eMMC+LP/DDR3 , ID : 150100524436344D42 : VEN : SAMSUNG   | DEV : RD64MB : RAM : [ 4,00 GB ]
     EMI : [0A] : eMCP : eMMC+LP/DDR3 , ID : 13014E53304A394237 : VEN : MICRON    | DEV : S0J9B7 : RAM : [ 3,00 GB ]
     EMI : [0B] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN   | DEV :  : RAM : [ 4,00 GB ]
     EMI : [0C] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN   | DEV :  : RAM : [ 4,00 GB ]
     EMI : [0D] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN   | DEV :  : RAM : [ 3,00 GB ]
     EMI : [0E] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN   | DEV :  : RAM : [ 6,00 GB ]
     EMI : Init EMI from PRELOADER
     EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
        SRAM: 0x00040000 [ 256,00 KB ]
        DRAM: 0xC0000000 [ 3,00 GB ]
        EMMC: 90014A484247346132A529661C37A433
        EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HBG4a2
        EMMC:
              BOOT1  : 0x00400000 [ 4,00 MB ]
              BOOT2  : 0x00400000 [ 4,00 MB ]
              RPMB   : 0x00400000 [ 4,00 MB ]
              USER   : 0x747C00000 [ 29,12 GB ]
        CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : D25C131EFC1EE670F939CD2FCB809311
DA : USB : HIGH-SPEED
Boot done!
Patch Level    : N6F26Q
Ver. CodeName  : REL
Ver. Release   : 7.1.1
Sec. Patch     : 2018-10-05
Build Time     : 1539797161
Product Manfct : OPPO
Board Platform : mt6763
Product Model  : OPPO CPH1723
Product Brand  : OPPO
Product Name   : CPH1723
Product Device : M6763A
Product Board  : full_oppo6763_17031
Product Info   : oppo6763_17031
SW Version     : A.30
SW OTA Version : M6763A_11.A.30_0300_201810172338
SW OTA Name    : CPH1723EX_11_A.30_181017
Display ID     : CPH1723EX_11_A.30_181017
Kernel Info    : 4.4.22-G201810172338
USERDATA : ENCRYPTED
Done!
Elapsed: 00:00:21
i understand... thank you JayDi bro for this
Old 11-28-2018, 13:29   #27 (permalink)
JayDi's Avatar
Member: 462970
With factory tools access. There some peoples selling service for it around. Have no idea.
Old 11-28-2018, 13:39   #28 (permalink)
Registered User
Member: 2462860
Thanks Meter: 71
done
done format oppo a83. thank a lot mr jaydi
The Following User Says Thank You to ORITECH For This Useful Post:
Old 11-28-2018, 13:45   #29 (permalink)
Member: 2596094
Thanks Meter: 83
Show log info.. .............
Old 11-28-2018, 13:50   #30 (permalink)
dany_boy's Avatar
Member: 1977629
Thanks Meter: 429
which resistor is better to use . i mean k power
The Following User Says Thank You to dany_boy For This Useful Post:
Page generated in 0.34201 seconds with 9 queries
