11-28-2018, 11:02 | #18 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Not have anything good to make shoot. Device disassembly require nothing, just remember about need start NOT from screen corner, but after it. Around sccreen corner plastic frame. After remove screws will void warranty. You had been warned. Remove battery connector, short TP, insert cable. After device connect - remove short. |
The Following 18 Users Say Thank You to JayDi For This Useful Post: |
11-28-2018, 11:04 | #19 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | BTW - seems as OPPO using/start using EFUSE to avoid downgrade - yes, like QLM! At first look You can flash older SW preloader, it will enter in brom loop, until new version will not be flashed. |
The Following 4 Users Say Thank You to JayDi For This Useful Post: |
11-28-2018, 12:01 | #21 (permalink) |
No Life Poster Join Date: Jul 2013 Location: Pakistan. Rahim Yar Khan
Member: 1977629 Status: Offline Thanks Meter: 429 | (Remove battery connector, short TP, insert cable. After device connect - remove short. ) after device conect need to place battery again to do some opreation for flash or format . ? or its work without battery |
11-28-2018, 13:29 | #25 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
So better not use, or use at own risk. Also, better use some resistor for better short circuit protection. | |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
11-28-2018, 13:29 | #26 (permalink) | |
Freak Poster Join Date: Aug 2016 Location: Karachi (PAKISTAN)
Member: 2609063 Status: Offline Thanks Meter: 103 | Quote:
i understand... thank you JayDi bro for this | |
