11-07-2015, 10:09 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: SL3 LBF IN Kamoke(Gujranwala)
Member: 481915 Status: Offline Sonork: 100.1604233 Thanks Meter: 476 | facing problem with smart av here is log: Code: Operation : Remove Viruses [SmartAV] [ v1.36 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZW5 [eMMC] : FLASH_CID : 1501004E35575A4D42010D27C2791131 [eMMC] : FLASH_EXT : 00100000/00020000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x00000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! USBDL : Init HSUSB Ok SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 58 Removing infected files and scripts ... DDCleaner : Error clear item #0 DDCleaner : Error clear item #1 DDCleaner : Error clear item #2 DDCleaner : Error clear item #3 DDCleaner : Error clear item #4 DDCleaner : Error clear item #5 DDCleaner : Too much errors! Break! Infected files not found! Breaking rest operations. Done! Done! Elapsed: 00:01:33 Reconnect Power/Cable! |
11-09-2015, 08:24 | #3 (permalink) |
Member: 481915 Status: Offline Sonork: 100.1604233 Thanks Meter: 476 | i made backup flash and write other flash but hanged on logo, then format, still there, then rewrite backup now phone is in first condition fully on having all viruses. if phone properly connected then all above process completed, here is the problem! Br. MianLinks |
