12-10-2007, 08:03 | #4 (permalink) |
Freak Poster Join Date: Jan 2007
Member: 424066 Status: Offline Thanks Meter: 43 | hello ==== log opened: [12/10/2007 9:59:01 AM] ==== Application: C:\Program Files\InfinityBox\prem\ChineseMiracle\ChineseMirac le.exe Loading data, wait... [Infinity Box] v2.07 S/N: 32A8:010C Wait... Device: Autodetect 6205-6227 NOR Done ==== log opened: [12/10/2007 10:10:13 AM] ==== Application: C:\Program Files\InfinityBox\prem\ChineseMiracle\ChineseMirac le.exe Loading data, wait... [Infinity Box] v2.07 S/N: 32A8:010C Wait... Device: Autodetect 6205-6227 NOR Done COM1 [Serial0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 31 sec Remove/Install battery now ! COM5 ready COM5 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6217:8A00]... boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... 921600 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb Warning: probably flash chip empty, erased, incorrectly flashed or damaged. What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\prem\ChineseMiracle\operation.lo g 2. C:\Program Files\InfinityBox\prem\ChineseMiracle\cfi_xxxx_xxx x.bin detecting chip #01 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device identification#1... detection phase #1... . detection phase #2... .......................... detect device identification#1 finished identification#1 protocol ver: 01 ver. sw1: LCT_X200_01_PCB01_GSM_MT6217_BN.L595704_5_36_1_0T0 1M0925_M401B.B ver. sw2: IN ffs offset/size: 36332E35/302E312E detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00700000 flash: 01227E22022201:FFFFFF00000000 checking area[00000000]: 00000000-007FFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00700000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 00100000 ffs chip: 00 eeprom/ffs area: 00000000:00700000-007FFFFF reading [flash[LCT_X200_01_PCB01_GSM_MT6217_BN.L595704_5_36_1_0T0 1M0925_M401B.B]]... file saved: C:\Program Files\InfinityBox\prem\ChineseMiracle\backup_flash[LCT_X200_01_PCB01_GSM_MT6217_BN.L595704_5_36_1_0T0 1M0925_M401B.B]_20071210-101536.B0M.bin Finished, time used: 180 sec Remove/Install battery now ! |
mpeg4 i658 dead. | sunny_gsm | Infinity-Box | 3 | 06-27-2008 13:16 |
5210 Dead Set (need Rply Badly) | WINPINPH1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 11-14-2003 04:58 |
8210 dead set problem | ryumahon | Nokia Hardware & Hardware Repair | 9 | 02-15-2002 07:35 |
16f Amd 2MB dead set | Hanukkah | Alcatel & TCL Old Models | 2 | 11-13-2001 13:10 |
3210 dead set Wahhhhh..... | MacGyver | Nokia Hardware & Hardware Repair | 3 | 08-09-2001 03:29 |
