06-19-2010, 15:43 | #1 (permalink) |
Junior Member Join Date: Jan 2009
Member: 938391 Status: Offline Thanks Meter: 2 | Firmware write problem COM20 [VCP0] selected module v3.15 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: write flash NAND write: Firmware NEOTEL35_08B_GEMINI_PCB01_GPRS_MT6235B_S01.LN233_H Y_V1_0R--100315__firmware_20100619-145422.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... bootloader version: NEOTEL35_08B_GEMINI_BOOTLOADER_V005_MT6235B_LN233_ HY_V1_0R.bin nfi area detection finished: Ok interface: BROM_DLL_v3.1012.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0005]: 00EC:0079005A003F [SAMSUNG] K9K1G08X0A chip size: 128Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 03000000/05000000 firmware size: 48Mb ffs size: 80Mb detect sec ro... detect custom parameters... detect project-id... project-id: LN233_HY_V1.0R detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: header is empty: probably flash chip completely erased warning: can not detect header nfi area detection finished: failed TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: NEOTEL35_08B_GEMINI_PCB01_GPRS_MT6235B_S01.LN233_H Y_V1_0R--100315.BIN project-id: LN233_HY_V1.0R, 00000000 code offset: 00000000 ffs offset/size [01]: 03000000/05000000 rom info structure: 2nd [standard] generation TCL-ID is absent ===> done ==================== New firmware detected (v.3.15, database date: 06.06.2010): NEOTEL35_08B_GEMINI_PCB01_GPRS_MT6235B_S01.LN233_H Y_V1_0R--100315.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== nfi area detection... bootloader version: NEOTEL35_08B_GEMINI_BOOTLOADER_V005_MT6235B_LN233_ HY_V1_0R.bin nfi area detection finished: Ok startup code area #1 check... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... write bootloader... error: can not write flash: 0FAE:S_FT_NFB_DOWNLOAD_BOOTLOADER_FAIL error: last error: 0FAE:S_FT_NFB_DOWNLOAD_BOOTLOADER_FAIL Disconnect... done Finished, time used: 55 sec Remove/Install battery now ! Thanks for your help in advance |
06-20-2010, 18:42 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, Please, be sure that you have enough free space at your HDD (at system and at current drive) due to software need a lot of free space at HDD for temporary files. |
06-21-2010, 17:30 | #3 (permalink) |
Member: 938391 Status: Offline Thanks Meter: 2 | The system and the current drive is the same and has more than 15GB free space. I think the prolem related to this 2 messages: "nfi area detection... warning: header is empty: probably flash chip completely erased warning: can not detect header nfi area detection finished: failed" "write bootloader... error: can not write flash: 0FAE:S_FT_NFB_DOWNLOAD_BOOTLOADER_FAIL error: last error: 0FAE:S_FT_NFB_DOWNLOAD_BOOTLOADER_FAIL" |
06-25-2010, 16:38 | #5 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, 1. double check phone battery voltage. It is very important to use fully charged battery ! 2. try to flash phone with original backup several time. What you see in operation log ? 3. Code: ==================== New firmware detected (v.3.15, database date: 06.06.2010): NEOTEL35_08B_GEMINI_PCB01_GPRS_MT6235B_S01.LN233_H Y_V1_0R--100315.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
