03-26-2008, 19:05 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, To avoid phone damage it's better to read flash from this phone (f.e. like KG290) and send flash backup to [email protected] to check. After we will check it we will be able to give you an advice what to do. |
04-04-2008, 15:34 | #5 (permalink) |
Freak Poster Join Date: Apr 2004 Age: 44
Member: 61643 Status: Offline Thanks Meter: 14 | ok reading flash and sending your adres -- > [email protected] |
04-04-2008, 20:44 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Converted file uploaded in support area: KG291iFL-01_V10d_208-20_AUG-26-2007_code+alchemy_w_calibration It's KG291i phone. I don't have experience with KG291i, but you can try to flash it with KG290 firmware. In case of any problems you can flash phone back with KG291i firmware. Use latest software (select model KG290): http://www.infinity-box.biz/download/public/LGA.rar |
04-12-2008, 01:04 | #7 (permalink) |
No Life Poster Join Date: Feb 2007 Location: india Age: 47
Member: 446363 Status: Offline Sonork: 1577571:rajtelecom Thanks Meter: 216 | Wait... Current device: LG B2000 Done Current device: LG KG290 Loading file v.02... KG291iFL-01_V10d_208-20_AUG-26-2007_code+alchemy_w_calibration.B1M.bin loaded Testing COM1 at 115200... COM1 [Serial0] selected Device: LG KG290 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Skip: Alchemy data Skip: Eeprom "smart write" enabled "keep calibration" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... error: boot failed: 78 Release Power button ! error: unexpected answer during boot procedure Boot Fail Finished, time used: 6 sec Remove/Install battery now ! Testing COM1 at 115200... COM1 [Serial0] selected Device: LG KG290 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Skip: Alchemy data Skip: Eeprom "smart write" enabled "keep calibration" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 357456011584920 file saved: C:\Documents and Settings\Raj\Desktop\LGA\backup_eeprom_35745601158 4920_LG KG290_20080412-043931.B1E.bin .............. Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) calibration area skipped flash: 89881600010001:89881600000000 flash: 89881600010001:89881600000000 Write Done error: wrong answer: C4 Finished, time used: 2788 sec Remove/Install battery now ! Loading file v.02... KG291i_repair_eeprom_01.B1E.bin loaded Testing COM1 at 115200... COM1 [Serial0] selected Device: LG KG290 Checking data, wait... advanced flash detection active Action: flash write Skip: Firmware (code) Skip: File system Skip: Alchemy data Write: Eeprom "smart write" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 357456011584920 file saved: C:\Documents and Settings\Raj\Desktop\LGA\backup_eeprom_35745601158 4920_LG KG290_20080412-052800.B1E.bin ........................................... Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Eeprom flash: 89881600010001:89881600000000 Write Done error: wrong answer: C4 Finished, time used: 72 sec Remove/Install battery now ! Testing COM1 at 115200... COM1 [Serial0] selected Device: LG KG290 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 358684012790142 file saved: C:\Documents and Settings\Raj\Desktop\LGA\backup_eeprom_35868401279 0142_LG KG290_20080412-052954.B1E.bin ........................................... Check flash Done Check space... current eeprom imei: 358684012790142 ....................................... finalization done Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... write: lock area-1 Write Done error: wrong answer: C4 Finished, time used: 79 sec Remove/Install battery now ! |
10-01-2009, 13:13 | #8 (permalink) |
Banned Join Date: Jul 2006 Location: dword ptr [ebp-1C], edx
Member: 322417 Status: Offline Thanks Meter: 940 | COM6 [VCP4] selected module v1.39 Device: LG-KG291i Checking data, wait... advanced flash detection enabled Action: reset Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 358684012672225 file saved: C:\Program Files\InfinityBox\LGA\eeprom_358684012672225_LG-KG291i_20091001-124925.B1E.bin ............. reading _eeprom-ffs_358684012672225... file saved: C:\Program Files\InfinityBox\LGA\_eeprom-ffs_358684012672225_LG-KG291i_20091001-130624.B1E.bin Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 4760 sec Remove/Install battery now ! Hang on logo format ffs phone ok |
06-02-2010, 07:00 | #9 (permalink) |
Junior Member Join Date: Oct 2007
Member: 619999 Status: Offline Thanks Meter: 4 | ks291 Press power on ! Starting communication ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Baud rate changed ok ! Flash ID(0): 0089:8816:0101 READING INFO ... WAIT ! (CAN TAKE ~60s) IMEI: ??????????????? LOCK: ??? Writting... Error ... ! Time needed - 00:01:24 |
can't flashing LG kg291 with infinity | sajib_ngage | Infinity-Box | 0 | 05-11-2009 08:49 |
Please Help, just need few flashing/unlocking answers - P520 | lomna | Samsung Flashers, Software, Firmware. | 3 | 02-03-2009 23:42 |
Enter Code In Lg Kg291??? | GHOSTMAN10 | LG | 5 | 03-12-2008 23:16 |
Code In Lg Kg291 | GHOSTMAN10 | LG | 0 | 11-21-2007 07:39 |
