02-14-2008, 12:11 | #1 (permalink) |
Insane Poster Join Date: Aug 2004
Member: 76625 Status: Offline Sonork: 100.1606726 Thanks Meter: 7 | flash lg ke970 i make flash with all versions from support (firmware , file system and epp) and phone is dead !!! forward time my phone show logo with ke970 and restart ... .. it was demaged with usb cable when transfer photo , melody .... any idea |
02-14-2008, 14:44 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, explain more detailed what was initial phone state, what was original firmware version, what you have tried to do and what files you have used. |
02-18-2008, 11:30 | #3 (permalink) |
Freak Poster Join Date: May 2004 Age: 44
Member: 64311 Status: Offline Thanks Meter: 110 | @infinity support hang on start up is been common problem with this ke970..in this state handset shows only logo appear for 7 secs disappear and then appear...this is surely software problem. i have been looking for soultion since long back and found no tool is successfuly able to repair this problem. i flashed this handset with KE970P40-AFR-V10i-***-XX_JUL-30-2007_file_system[1].B1S but handset got dead..i rollback this handset by flasing it again with gsmulti but not repaired ok. tried all the option in infinity....hope soon there will be solution for this |
02-18-2008, 17:27 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Just for info: firmware + FileSystem + repair_eeprom = virgin phone. My advice: try to double check phone hardware, reball flash IC and CPU, let's see results. |
02-22-2008, 04:22 | #5 (permalink) |
Junior Member Join Date: Feb 2008
Member: 713005 Status: Offline Thanks Meter: 0 | I am having the same problem with the KE970. After I dropped it I got the logo display and freeze problem which seems to be so common. However, if you put in an inactive SIM card the phone will startup normally but you can only dial emergency numbers and even if you scan for networks it will detect the local networks (Tmobile, Cingular). If you try to power it on with an active SIM it just freezes on the logo screen. With the inactive SIM in I went to the admin menu (2945#*#) to try and reset it to factory settings but it freezes with the "Resetting..." message this time...horrible horrible!! Infinity is perhaps right and it might be a hardware problem as I initially assumed since it started with the drop. The freeze obviously occurs when the SIM tries to register on the network..otherwise why would it power on with an inactive SIM?? Infinity, if you do not mind briefly explaining how to "reball flash IC and CPU" I would like to give it a shot. Any help and troubleshooting tips on this problem are greatly appreciated. cheers |
02-22-2008, 09:59 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, "reball" means: 1. desolder chip 2. solder it back "reball" name is a result of soldering method of BGA chip. Probably right name is "resolder". You can see balls on this picture: C:\Program Files\InfinityBox\Documentation\test_point\Moto\Mo to_E365_repair_test_point.jpg |
What cable to flash LG KE970...??? | Krzychu23 | LG | 15 | 01-12-2010 08:45 |
Successfully Flash LG KE970 | coolderheart | HWK | 2 | 04-03-2009 10:36 |
Flash LG ke970 with file support problem | let go | FuriousGold | 2 | 03-13-2009 16:10 |
did any one flash lg ke970 successufully with hwk | f164 | HWK | 6 | 02-09-2009 21:56 |
Sucessfully Flashed LG KE970 IN 2HRS 30 MIN | unlock trigger | Infinity-Box | 5 | 10-22-2008 13:55 |
