10-17-2020, 12:51 | #1 (permalink) |
No Life Poster Join Date: Sep 2008 Location: Bohicon (Rep of Benin)
Member: 862014 Status: Offline Sonork: 100.1608307 Thanks Meter: 64 | Flash tecno cf8 error i have 3 tecno cf8 which have this problem. when try to flash it display this error. the batery it full but no change Operation : Write Flash [ v2.16 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :20 [FL] : Set : preloader_cf8_h612.bin [FL] : Set : recovery-verified.img [FL] : Set : tranfs.img [FL] : Set : md1img-verified.img [FL] : Set : spmfw-verified.img [FL] : Set : scp-verified.img [FL] : Set : scp-verified.img [FL] : Set : sspm-verified.img [FL] : Set : sspm-verified.img [FL] : Set : lk-verified.img [FL] : Set : lk-verified.img [FL] : Set : boot-verified.img [FL] : Set : logo-verified.bin [FL] : Set : odmdtbo-verified.img [FL] : Set : tee-verified.img [FL] : Set : tee-verified.img [FL] : Set : vendor.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0xC9874068 [ 3,15 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM4) MODE : PRELOADER PORT PORT : 4 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : TECNO : [Hovatek] Tecno Camon CF8 DA file | Manual : Disabled BROM : SOCID : C0914B616BCF0CDED067A73A9BFD1279D28937B830177BD06A 2B674E5187B903 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256,00 KB ] DRAM: 0x180000000 [ 6,00 GB ] EMMC: 90014A484347386134A209E4F0E285A9 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HCG8a4 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0xE8F800000 [ 58,24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 4928C49F31B5AD2B83672362F06B896F DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000016288000 Erase : 0x0000000018288000 : 0x0000000006000000 Erase : 0x000000001F800000 : 0x0000000000800000 Erase : 0x0000000023000000 : 0x0000000000200000 Erase : 0x0000000023500000 : 0x0000000008900000 Erase : 0x000000002FE00000 : 0x00000001E5200000 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader backup copy ... Update bootloader backup copy Ok! Write : RECOVERY FAIL : INVALID GPT ERR : 0xC0030008 ERR : INVALID GPT ERR : 0x00000000|0x00E2A3A0 Error : Flashing failed! >>> Seems as something wrong with device! Check battery charge and device state! Reconnect Power/Cable! someone can help me to know how solve this pbm? |
10-17-2020, 12:57 | #2 (permalink) |
Freak Poster Join Date: Apr 2007 Location: algeria
Member: 481774 Status: Offline Sonork: [email protected] Thanks Meter: 174 | remove battry . connect usb without pressig any key check and reply |
10-17-2020, 14:18 | #3 (permalink) |
Member: 862014 Status: Offline Sonork: 100.1608307 Thanks Meter: 64 | samething bro but think for your help Write : PRELOADER Update bootloader backup copy ... Update bootloader backup copy Ok! Write : RECOVERY FAIL : INVALID GPT ERR : 0xC0030008 ERR : INVALID GPT ERR : 0x00000000|0x00E2A3A0 Error : Flashing failed! >>> Seems as something wrong with device! Check battery charge and device state! Reconnect Power/Cable! |
10-19-2020, 09:56 | #5 (permalink) |
Member: 862014 Status: Offline Sonork: 100.1608307 Thanks Meter: 64 | i I THINK that no, this is not a HW problem because at first it connects, takes a flash to the end and does not turn on and it is when I download another version that it started by doing this stupidity. we don't even take it apart. Now if this is the case with HW, as it is repeated all the time on the forums, what is the real solution to this? which box actually does it? |
