01-10-2008, 08:08 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: United Kingdom
Member: 109729 Status: Offline Thanks Meter: 36 | Format cect t689 not work general information Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6205B, E0 Hardware version: M50ZS_HW Software version: E550AGENT_S1.01.6" Software date: 2003.07.29 Barcode: MT012345678901234567 imei: 135790246811220 Finished, time used: 4 sec Power off phone now ! detalied information: COM2 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read/check detailed information Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6205:8B00]... boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #02 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #03 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #04 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #05 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #06 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #07 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 08/01 Initialize Done Set baud... 115200 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00400000 detect device identification#1... detection phase #1... . detection phase #2... . . . . . . detect device identification#1 finished identification#1 protocol ver: 02 ver. sw1: E550AGENT_S1_E550_GSM_MT6205B_DN.01_6.BIN ver. sw2: E550AGENT_S1.01.6 ffs offset/size: 00190000/00070000 detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00190000 flash: 01227E221A2201:18E59F00000000 checking area[00000000]: 00000000-003FFFFF... eeprom/ffs found near: 00190000 detecting eeprom/ffs size... eeprom/ffs size: 00270000 ffs chip: 00 eeprom/ffs area: 00000000:00190000-003FFFFF detecting ffs structure pass 1... . . . . . detect standard fat location pass #1... . . . . . detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #1 detected ok Finished, time used: 45 sec Remove/Install battery now ! and when i try to format in safe mode alaways i have this error: OM2 [VCP0] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6205:8B00]... Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 41 sec Remove/Install battery now ! i use pinout from back label and i keep pressen power on button more than 40 sec.. anny solution please? |
01-10-2008, 13:39 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | @TEHGSM You have found pinout for 2nd CPU (2nd SIM). Ordinary dual sim phones has MT6226 main CPU and MT6205 2nd CPU. According to your log you tried to format 2nd CPU: Initializing[6205:8B00]... So, try to find pinout for 1st main CPU and format it. |
01-11-2008, 15:25 | #4 (permalink) |
Member: 109729 Status: Offline Thanks Meter: 36 | Done'it!! I used phone connector pinout 1 & 2 GND 7 Rx 9 Tx Make format wihtbout anny problem and after that write imei with second method. phone work 100 % so thank's to all for help. wbr. tehgsm romania |
01-18-2008, 10:54 | #6 (permalink) | |
No Life Poster Join Date: Jan 2003 Location: romania brasov Age: 46
Member: 19672 Status: Offline Sonork: 100.65069 Thanks Meter: 46 | Quote:
Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6205:8B00]... boot step size: 0400 error: bootcode load error: 6002E2867002E2870008E156FFE83AFF0004E1A0FFBAEBFF00 05E1A081F0E8BD4038E92D5000E1A03134E59F3004E5931EA0 E28300AAE3A00ABAE1C11E50E2830055E3A005B4E1C11EA0E2 830080E3A00ABAE1C11EA0E28300AAE3A00ABAE1C11E50E283 0055E3A005B4E1C10030E3A000B0E1C50005E1A010ECE59F00 26EB004000E1A0FF9EEBFF0004E1A08038E8BD4010E92D0000 E3A08010E8BD4004E92D20BCE59F2004E5920EA0E28210AAE3 A01ABAE1C00E50E2821055E3A015B4E1C00EA0E2821020E3A0 1ABAE1C08004E8BD1090E3A010B0E1C01000E3A010B0E1C0F0 0EE1A01080E3A010B0E1C01010E3A010B0E1C0F00EE1A01098 E3A010B0E1C0F00EE1A0400CE92D3EA0E28020A0E3A02ABAE1 C310B0E1C080CC00 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 13 sec Remove/Install battery now ! | |
01-18-2008, 12:46 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! wait few weeks. soon we will annonce our automaticly finding pinout box_addon it will contain all needed cables and will find pinout automaticly |
problem formating Cect T689 | saranda | Infinity-Box | 3 | 03-25-2008 21:54 |
CECT T689 Not suported full beckup | AKKA | Chinese Cocktail | 2 | 02-23-2008 06:59 |
