01-20-2019, 01:26 | #1 (permalink) |
Freak Poster Join Date: Feb 2006
Member: 233369 Status: Offline Thanks Meter: 23 | frp mi a2 fail 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... BREAK : Device not found! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Read PatternLock [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 660 [MSM8956 Plus] ID_BLOCK_S : 5F9D8582 ID_BLOCK_L : 6C6870EE956258118C1238CA8973A799 ID_BLOCK_L : 6BF0BBCECDAFF2B2D1011C38A6011D9A Use CM2 Internal Loader FH_LOAD_CODE : 15 ERROR : Loader send failed! HINT : Check cable, connection and drivers! Reconnect Power/Cable! |
