03-23-2018, 10:30 | #1 (permalink) |
Junior Member Join Date: Jan 2005 Age: 54
Member: 107557 Status: Offline Thanks Meter: 0 | FRP MTK 8163 [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! ERROR IN FRP UNLOCK Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 49 ] Sync... Inital Boot Ok! BB_CPU_PID : 8163 BB_CPU_NME : [MediaTek] MT8163_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:10 Reconnect Power/Cable! |
03-23-2018, 10:43 | #2 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Balkan Age: 50
Member: 1473716 Status: Offline Thanks Meter: 1,273 | ACER ICONIA ONE 10 B3-A20 frp Use volume + and volume - and conect to usb....... Or try with this.... https://www.youtube.com/watch?v=gvOu...ture=********* |
03-23-2018, 10:52 | #3 (permalink) |
Member: 107557 Status: Offline Thanks Meter: 0 | VOLUMEN + AND - AND COME OUT THIS NEW ERROR Wait for phone... Phone found! [ 50 ] Sync... Inital Boot Ok! BB_CPU_PID : 8163 BB_CPU_NME : [MediaTek] MT8163_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x97 NAND Flash : NOT INSTALLED eMMC Flash : 4501004453323033320127E53850B2F1 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xBC000000 DRAM_INIT_REQ_FAILED Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! |
03-24-2018, 22:49 | #4 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Try with attached DA Agent. Rename and put to corresponding folder. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
The Following 3 Users Say Thank You to Brka For This Useful Post: |
