01-13-2010, 11:28 | #1 (permalink) |
Freak Poster Join Date: Dec 2009 Location: Poland / England Age: 44
Member: 1196235 Status: Offline Thanks Meter: 27 | Which fullflash match witch Language pack editor: MCU version: MAUI.08B.W08.52.MP.V2.090905 Build time: 2009/11/23 11:55 Hardware: F25_08B_GEMINI_HW China miracle - GENERAL Action: read/check information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6225, E05 Hardware version: F25_08B_GEMINI_HW Software version: MAUI.08B.W08.52.MP.V Software date: 2006.06.14 Barcode: MT012345678901234567 imei-1: 351695019898826 imei-2: 351695019898826 imei-3: 351695019898826 Finished, time used: 7 sec Remove/Install battery now ! China miracle - DETAILED COM9 [VCP0] selected module v3.05 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:7103:000F status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 05 sw version: HEXING25_08B_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08B _W08_52_MP_V2_090905.BIN project-id: MAUI.08B.W08.52.MP.V2.090905, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting ffs/eeprom structure pass 1... ............................. detect standard ffs/eeprom location pass #1... .................................................. ... detect standard ffs/eeprom offset pass #1... ffs/eeprom record offset detected detect standard ffs/eeprom data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished detecting firmware version... firmware version: HEXING25_08B_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08B _W08_52_MP_V2_09 detecting firmware build... .................................................. ... firmware build: 200911231155 detecting product-id... .................................................. .............. done detecting languages... ............................................ language parameters detected detected languages: En Es It Pl sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Finished, time used: 2 min 1 sec Remove/Install battery now ! My question is: Which fulflash form support match witch this phone Please help. |
01-13-2010, 18:27 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! here is your file on support: flashfiles/ChineseMiracle/_MT6225/HEXING25_08B_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08B _W08_52_MP_V2_090905_16m_En_Fr_Tr_Hi_Urdu_Farsi_Pt _Ar.B0M.bin please make full backup before flashing and also, in a first place, try to solve your problem by format FFS. only if this will not help- continue by flashing |
01-14-2010, 11:05 | #4 (permalink) |
Member: 1196235 Status: Offline Thanks Meter: 27 | I was try: HEXING25_08B_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08B _W08_52_MP_V2_060703_16m_En_Ru_Fr_Es_Ml_Id_Tr_Fars i_Pt_Ar.B0M.bin HEXING25_08B_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08B _W08_52_MP_V2_060715__Nokia-E71TV+_16m_En_Ru_Fr_Es_Ml_Th_Pt_Ar.B0M.bin HEXING25_08B_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08B _W08_52_MP_V2_0622__E71i_16m_En_Ru_Fr_Es_Ml_Th_Tr_ Pt_Ar.B0M.bin HEXING25_08B_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08B _W08_52_MP_V2_090728__NOKIA-E71_16m_En_Ru_Fr_Es_It_Id_Tr_Farsi_Pt_Ar.B0M.bin HEXING25_08B_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08B _W08_52_MP_V2_090905_16m_En_Fr_Tr_Hi_Urdu_Farsi_Pt _Ar.B0M.bin HEXING25_08B_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08B _W08_52_MP_V2_16m_En_Es_Pt.B0M.bin NEOTEL25_08B_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08B _W08_52_MP_V22_F2__NOKIA-8800e_16m_En_Ru_Id_Tr_Ar.B0M.bin but maybe other match too.. |
01-14-2010, 19:40 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! what about my advice? format FFS or adviced flash file? both did not work out? you can try other firmwares too (thoise which you mentioned in the post above) |
please.....which cable match with nokia 6085 ?????????? | rumenshom | Nokia Hardware & Hardware Repair | 5 | 01-18-2009 10:32 |
which lcd match wid NOkia 2600c???? | asrar | Nokia Hardware & Hardware Repair | 4 | 01-03-2009 06:33 |
which lcd strip match with LG, KE970 | asrar | LG | 1 | 05-30-2008 17:09 |
Pls which flashfile in support match these????? | kaino147 | Infinity-Box | 1 | 09-22-2007 21:22 |
Which product code is needed for E61 to match UK keypad layout? | JCJiffy | Nokia Base Band 5 ( BB-5 ) | 0 | 09-06-2006 04:21 |
