06-16-2021, 11:54 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello! https://cdn.infinity-box.com/tmp/CM2SP2_boot.7z Unpack to CM2SP2 main folder. Start SP2 , select Moto -> G20. Connect as software asks. |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
08-28-2021, 21:26 | #3 (permalink) |
No Life Poster Join Date: Apr 2005 Location: America
Member: 138781 Status: Offline Thanks Meter: 850 | fail frp moto g20 Operation : Format FS / Reset Settings [ v2.13 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Moto : G20 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe failed! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:01:03 |
08-29-2021, 21:48 | #4 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Looks like it dont allow erasing userdata, so try this : Manually enter recovery, make factory reset, all should be fine. post results b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
09-21-2021, 01:12 | #5 (permalink) | |
Freak Poster Join Date: Oct 2007
Member: 607283 Status: Offline Thanks Meter: 10 | Quote:
that link already expired Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7715_BASE : SC7715_eMMC_512MB_NS Sending Init Boot ... Boot sent! Kick FDL ... Kick FDL again ... >>> ERROR : FDL NOT started! >>> Error : Fail to boot FDL! >>> Unsupported device with selected fdl or settings! Change settings! Reconnect Power/Cable! | |
09-26-2021, 04:28 | #6 (permalink) | |
Freak Poster Join Date: Jun 2013 Location: mexico
Member: 1958094 Status: Offline Thanks Meter: 57 | Quote:
Operation : Identify [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : P352CE_PVT_11.0_64B_CFC_68-4.00-00.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:01:08 | |
09-26-2021, 05:26 | #7 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Quote:
USE CORRECT OPTION TO DO JOB WBR sahil2000ind | |
09-30-2021, 07:19 | #9 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
