08-08-2011, 01:57 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: rochdale uk
Member: 396778 Status: Offline Thanks Meter: 155 | G6603 dead cant flash it module v3.82 Device: Huawei-G6603 Checking data, wait... Action: write flash NAND write: Firmware Huawei-G6603_BYD35_09A_PMWY_PCB01_GPRS_MT6235B_S01.E5_2EU 01V01_04_2011-03-11_En_Virgin.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs firmware patch (sp-lock #1)... not required firmware patch (sp-lock #2)... not required nfi area detection... bootloader version: BYD35_09A_PMWY_BOOTLOADER_V005_MT6235B_E5_2EU01V01 _04.bin nfi area detection (3 cores) finished: Ok "format ffs" active interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0053]: 00AD:00A100000015 [HYNIX] H8BCS0PG0MBP chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: E5.2EU01V01.04 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: BYD35_09A_PMWY_BOOTLOADER_V005_MT6235B_E5_2EU01V01 _04.bin warning: id-page1 area is invalid nfi area detection (0 cores) finished: failed TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: BYD35_09A_PMWY_PCB01_GPRS_MT6235B_S01.E5_2EU01V01_ 04.BIN project-id: E5.2EU01V01.04, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.3.82, database date: 04.04.2011): BYD35_09A_PMWY_PCB01_GPRS_MT6235B_S01.E5_2EU01V01_ 04.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare â Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== nfi area detection... bootloader version: BYD35_09A_PMWY_BOOTLOADER_V005_MT6235B_E5_2EU01V01 _04.bin nfi area detection (3 cores) finished: Ok startup code area #1 check... done number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . . . . . . . . . . write core... error: can not write flash (0): 0FAF:S_FT_NFB_DOWNLOAD_CODE_FAIL error: last error: 0FAF:S_FT_NFB_DOWNLOAD_CODE_FAIL Disconnect... done Finished, time used: 3 min 57 sec Remove/Install battery now ! phone was fully working order, and i tried to unlock it but i got the message that its got a new firmware and i tried to flash from support area and now phone gone dead. any help plz thanks |
08-08-2011, 12:18 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | If you see message about new firmware you DO NOT need to flash phone !!! Please, next time read text given by software and follow it !!! We did not asked users to flash phones, we always ask them just read flash and send to support !!! What to do now: 1. charge battery with external power supply 2. install latest MModule software version 3. flash phone again |
08-08-2011, 15:35 | #3 (permalink) |
Member: 396778 Status: Offline Thanks Meter: 155 | thanks for reply i have tried it but still same problem COM20 [VCP0] selected module v3.99 Device: Huawei-G6603 Checking data, wait... Action: write flash NAND write: Firmware Huawei-G6603_BYD35_09A_PMWY_PCB01_GPRS_MT6235B_S01.E5_2EU 01V01_04_2011-03-11_En_Virgin.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... bootloader version: BYD35_09A_PMWY_BOOTLOADER_V005_MT6235B_E5_2EU01V01 _04.bin nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0053]: 00AD:00A100000015 [HYNIX] H8BCS0PG0MBP chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (115200)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: E5.2EU01V01.04 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: BYD35_09A_PMWY_BOOTLOADER_V005_MT6235B_E5_2EU01V01 _04.bin warning: id-page1 area is invalid nfi area detection (0 cores) finished: failed TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: BYD35_09A_PMWY_PCB01_GPRS_MT6235B_S01.E5_2EU01V01_ 04.BIN project-id: E5.2EU01V01.04, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done nfi area detection... bootloader version: BYD35_09A_PMWY_BOOTLOADER_V005_MT6235B_E5_2EU01V01 _04.bin nfi area detection (3 cores) finished: Ok startup code area #1 check... done number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . . . . . . . . . . write core... error: can not write flash (2): 0FAF:S_FT_NFB_DOWNLOAD_CODE_FAIL error: last error: 0FAF:S_FT_NFB_DOWNLOAD_CODE_FAIL Disconnect... done Finished, time used: 4 min 47 sec Remove/Install battery now ! |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
SIM restriction pending -- what does it mean? | Ryu | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 07-17-2011 10:05 |
