07-09-2017, 12:59 | #1 (permalink) |
No Life Poster Join Date: Feb 2009 Location: India
Member: 982335 Status: Offline Thanks Meter: 202 | Gionee f103 repair security not done.. CM2 SHOWS DONE BUT PROBLEM NOT SOLVED. THIS IS FULLY WORKING PHONE BUT CM2 SHOWS "PRELOADER ERASED". FLASH WITH LATEST VERSION BUT SAME. NEED HELP. LOGS.. [AP] : Initial info read Ok! Brand : GiONEE ProdName : F103 ProdModel : F103 Device : GiONEE_GBL7319 AndroidVer: 6.0 MTKxCPU : MT6735 MTKxPRJ : GBL7325GI_0203_T8325 Done! Elapsed: 00:00:15 Reconnect Power/Cable! Card found : S/N : 872***** , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Fix Unknown BaseBand [ v1.58 ] User accepted FixBB operation! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 520001154D313238FC4600421F1C71D4 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x80000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM128 [eMMC] : FLASH_CID : 150100523832314D420046FCD471721F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xFF776E8CEEE3BDC7DF4A070659A80668 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Step #1 Step #1 ... Ok Step #2 Step #2 ... Ok Reset Done! Done! Elapsed: 00:00:15 Reconnect Power/Cable! Operation : Repair Security [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 520001154D313238FC4600421F1C71D4 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x80000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM128 [eMMC] : FLASH_CID : 150100523832314D420046FCD471721F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xFF776E8CEEE3BDC7DF4A070659A80668 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! USBDL : Init HSUSB Ok Set IMEI [00] : 867865********* Set IMEI [01] : 867865********* Prepare finished. Security check required! Wait for phone... Phone found! [ 4 ] Sync... Repair done! Done! |
