09-08-2008, 16:41 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Location: SBZ-TUNISIA Age: 54
Member: 104036 Status: Offline Thanks Meter: 44 | Good operation in my200x Code: ==== log: [07/09/2008 21:50:25] ==== COM5 [VCP0] selected Device: Sagem-my220x Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-sta_20080907-215046.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-sec_20080907-215049.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-complete_20080907-215055.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 85 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 Code: ==== log: [07/09/2008 21:49:40] ==== COM5 [VCP0] selected Device: Sagem-my220x Checking data, wait... Action: read eeprom Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-sta_20080907-215001.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-sec_20080907-215006.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-complete_20080907-215012.B1E.bin backup critical area Done Check memory... completed Finished, Remove/Install battery now ! Time used: 30 sec Code: ==== log: [07/09/2008 22:02:08] ==== COM5 [VCP0] selected Device: Sagem-my220x Checking data, wait... Action: read flash Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 460800 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-sta_20080907-220224.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-sec_20080907-220228.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-complete_20080907-220230.B1E.bin backup critical area Done Check memory... reading [flash]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_flash_20080907-220443.B1X.bin completed Finished, Remove/Install battery now ! Time used: 158 sec |
The Following User Says Thank You to youssef70 For This Useful Post: |
11-19-2008, 00:00 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
<<< Need USED Mt-Lite + microscope in Good condition in PAKISTAN >>> | Faisal_Computer | Wanted Products | 1 | 06-14-2008 04:50 |
In which operations in Cruiser plus id -07 are results logged? | VATWork | Cruiser Suite | 2 | 03-07-2008 12:04 |
looking for buy good repairing tools from good shop in UAE | motaharo | Wanted Products | 7 | 09-07-2006 08:39 |
355 dead after some operations in delok | 2xxu | DELOK DONGLE | 0 | 05-24-2005 22:43 |
Sim with 2 operators in the same time | andreic | Sim Cloning and Scaning | 2 | 03-21-2002 18:08 |
