03-26-2008, 21:29 | #1 (permalink) |
Crazy Poster Join Date: Dec 2004 Age: 48
Member: 95661 Status: Offline Thanks Meter: 1 | Gtran N150 From Digitel Venezuela http://rapidshare.com/files/10260096...340.B0X.r.html BEST REGARDS |
03-27-2008, 10:16 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, download latest software for test here: http://www.infinity-box.biz/download...dule_v2.15.rar Please, try to unlock N120 by different methods (it was made some improvements). Please, let me know about results. |
03-27-2008, 15:40 | #5 (permalink) |
Member: 95661 Status: Offline Thanks Meter: 1 | log file ==== log opened: [27/03/2008 09:53:54 a.m.] ==== Application: C:\Archivos de programa\InfinityBox\MModule\MModule.exe Loading data, wait... [Infinity Box] v2.15 S/N: 233F:010E Wait... Device: Gtran N120 Done COM3 [VCP0] selected Device: Gtran N120 Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: unlock unlock method: standard Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6227:8A02:8A01]... CPU: MT6227 chip: 0031:0541:0884 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 89881500010001:89881500000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: KCM_PCB01_GPRS_MT6227_S01.MAUI_06A_W06_44_MP_V20.B IN ver. sw2: MAUI.06A.W06.44.MP.V20, 00000000 ffs offset/size: 00E00000/001E0000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[KCM_PCB01_GPRS_MT6227_S01.MAUI_06A_W06_44_MP_V20.B IN]]... file saved: C:\Archivos de programa\InfinityBox\MModule\backup_eeprom[KCM_PCB01_GPRS_MT6227_S01.MAUI_06A_W06_44_MP_V20.B IN]_20080327-095821.B0E.bin flash: 89881500010001:89881500000000 Backup required data Done Patch required data... detection procedure, wait... detection procedure completed Patch required data Done Special operation... detecting additional parameters... .................................................. .............. error: additional parameters detection failed detecting additional parameters... .............................................. flash: 89881500010001:89881500000000 flash: 89881500010001:89881500000000 Write: area 1/1 .................. additional parameters detected Ok Special operation Done Write... flash: 89881500010001:89881500000000 Write: eeprom Write Done Finalization... Finalization Done Finished, time used: 357 sec Remove/Install battery now ! COM3 [VCP0] selected Action: read codes unlock method: read codes Model: Gtran N120 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6227:8A02:8A01]... CPU: MT6227 chip: 0000:0000:0000 error: initialize step#1 failed Can't initialize test mode ! Possible reasons: 1. communication fault, repeat required operation 2. eeprom/ffs serious damaged, use repair eeprom/ffs files or use other unlock/format method error: operation failed ! Finished, time used: 19 sec Remove/Install battery now ! COM3 [VCP0] selected Action: read codes unlock method: read codes Model: Gtran N120 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6227:8A02:8A01]... CPU: MT6227 chip: 0031:0541:0884 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6227,E02 Date: 2005.04.12 Version: 1.0 Version: MAUI.06A.W06.44.MP.V20 Version: J2_MAIN_Rev02 42 byte(s) read imei: 35552200161977 connection Ok 148 byte(s) read Phone lock: Off Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 0000 Finished, time used: 10 sec Remove/Install battery now ! look at this when i use standard unlock appear unlock but not, when i unlock way read codes apper is unlocked but whan i insert any sim include digitel sim the phone say invalid sim card, i try to change imei and change but still locked |
03-30-2008, 11:44 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If somebody can send to us locked N120 or N150 for test, please, contact to Infinity-Box forum member or by e-mail: [email protected] We will pay for phone + delivery. Thank you ! |
06-04-2008, 12:13 | #14 (permalink) | |
Hello, I am very sorry to remind you, but you have made your post in Infinity-Box support forum. So if you need to make required operation you need to have Infinity-Box. You can get more details here: www.infinity-box.com www.infinity-box.biz | |
Unlock Blacberry 8220 Digitel Venezuela Is Posible | Braycel | BlackBerry (RIM) | 6 | 03-05-2009 04:06 |
NOKIA 5200 lcoked to DIGITEL VENEZUELA | klantech | Phone Unlocking Codes & Maps | 1 | 08-31-2007 19:44 |
U6 Digitel Venezuela | Cibernetic | Smart-Clip | 3 | 12-20-2006 09:21 |
