H688 TV phone second sim "emergency" calls hi all.... i have H688 [tv phone] this is the firmware on it MTK26_05C_MASTER_PCB01_GPRS_MT6226_S01.MAUI_05C_W0 6_16 the problem is that the phone has 2 lines one of them is working fine, the other one is emergency calls always i formated both ffs for both MCUs i changed IMEI i made repair security area. same problem, this is the full info: Hardware version: MT6226, E02 Hardware version: MALATA26_05C_HW Software version: MAUI.05C.W06.16" Software date: 2005.04.12 Barcode: MT012345678901234567 imei: 555555555555558 how can i know the other IMEI of the phone? thanks in advance BR Mansi |
hello! i would advice to write no just any number instead of IMEI, but write some valid IMEI from working set. first IMEI you can see by typing *#06# second IMEI you can see on GSM tester or connect infiniy box to CPU2 terminals and read out phone info. please, write there some Vaild IMEI number, not 55555555555555 and post result |
unfortunately i returned the set back to the customer, but any way, i have tried to write correct IMEI [valied IMEI like 350........], for both CPU's, and i got same result, if the customer give it back to me, then i will try another time with [2nd CPU]. thank you for the help any way. BR Mansi |
hello! if phone will return to your hands- also pay attention if it is possible to see available networks in "Netowrk search" menu. |
ok i will. thanks for your help BR Mansi |
SO PLZ INFINITY MOR EXPLAIN BR |
hello mr. sayedhas! first, you explane what means "same problem" which sim card is not working? first or second? did you check for IMEIs? both correct? did you try to write new IMEIs to both phone parts? |
hi i have same problem frist sim emergency mode but second work fine when i try to manua search i see all network when i try to connect to sim network phone show try again later i try to flash phone wit flash from support area(flash+epprom) make repair and repair iemi also how can i write second iemi thk |
hello! first CPU operation you doing via pinout for CPU_a second CPU operation you doing via pinout for CPU_b i think in your case you just need to set correct (valid) IMEI for both phone parts try this and reply |
can i write the same(valid) imie for both cpu or i can write 2 diffrant imie ? |
sometimes its hardware problem. |
hello! i would advice not to write to both parts 1 IMEI. In some countrys operator is not allowing two same IMEIs to stay in one network. I will tell more: some country operators block phones where last IMEI check digit is incorrect. that is why our soft always calculate valid last IMEI check digit |
How can i read second cpu, because, i read fullflash the second cpu, after downloading bootloader, phone is always on it self. may i know where is cpu2 power button? Thanks |
hello! CPU 2 power button is same as CPU1. when you booting second MCU phone acts like this: 1. you press power button and hold it. 2. Phone start normaly, you can see "Insert SIM", but you still keep power button pressed! 3. after around 30seconds you will see that program detected second MCU 4. You still keep power button untill software asks to release it |
See this thread http:///showthread...51#post3170351 Post number 7 |
