12-03-2019, 09:59 | #1 (permalink) |
Freak Poster Join Date: Sep 2012
Member: 1808452 Status: Offline Thanks Meter: 21 | Hello team, is my smartcard damaged or what? I removed the smartcard and inserted in different smartcard reader but the result is still same. When using dongle manager, this is what I get "Searching... Dongle can't be found: Card with specified AID is not found" Last edited by busfield; 12-03-2019 at 10:06. |
12-03-2019, 11:24 | #4 (permalink) | |
- Select Card-Reader - Click to "Read" button DO NOT send screenshot/video but copy/paste text from software window ! | |
12-03-2019, 11:56 | #6 (permalink) |
Member: 1808452 Status: Offline Thanks Meter: 21 | Card-Reader: Generic EMV Smartcard Reader 0 ATR: 3B7F96000080318065B0850201F312FFFE829000 Card Manager: A000000018434D00 Send + Receive error. ISO7816 error 0x6D00 (Instruction code not supported or invalid) |
12-03-2019, 13:54 | #7 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Try to connect Dongle to another PC Try to insert Smart-Card into another Card-Reader or Box (if you have it) If problem still exist: - Remove Smart-Card from Card-Reader - Clean Smart-Card contacts - Try to use hot air gun and heat Smart-Card - Insert Smart-Card back to Card-reader If problem still exist it may be a hardware problem. |
12-03-2019, 16:02 | #12 (permalink) |
Member: 1808452 Status: Offline Thanks Meter: 21 | If my smart-card is damaged, please kindly transfer my activations and support from old card with S/N 524131c7 to this new card with S/N AC3E9B66 Thanks. What might have caused my smart-card to get damaged because I don't have any sniffing or cracked software on my pc |
12-03-2019, 22:30 | #13 (permalink) | |
No Life Poster Join Date: Jan 2016 Location: Gsm flashing
Member: 2521913 Status: Offline Thanks Meter: 251 | Quote:
12-04-2019, 11:09 | #14 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Dongle 524131C7 is from year 2016 so it's quite strange that it become unreadable. As I can see it's not first time when your card become damaged so PC usb port voltage and also consider do not use old card-reader and do not use old one. activation transferred, update AC3E9B66 now butbe noted that this card is older than 524131C7 |
12-04-2019, 11:39 | #15 (permalink) |
Member: 1808452 Status: Offline Thanks Meter: 21 | Thank you YellowBoss === DongleManager [Infinity] v1.72 [04/12/2019 10:37:40] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 00089B6618201292 Box/Dongle found: [BEST] Reading... Serial No (S/N): AC3E9B66 Firmware version: 0122.02 === Process started: 04/12/2019 10:37:41 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... Wait 4-5 minutes ! DO NOT disconnect Box/Dongle ! Applet upgrade ok Checking Dongle Identification... Identification Ok. Finalizing... Finalizing ok Process completed === Process finished: 04/12/2019 10:37:57 === === DongleManager [Infinity] v1.72 [04/12/2019 10:37:57] === Box/Dongle type selected: [BEST] Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 00089B6618201292 Box/Dongle found: [BEST] Serial No (S/N): AC3E9B66 Firmware version: 0122.02 => Activations: - 00: Infinity-Box/Dongle v.0137 - 03: [BEST] v.0122 |
