05-28-2012, 21:33 | #2 (permalink) |
No Life Poster Join Date: Feb 2003 Location: africa Age: 54
Member: 22284 Status: Offline Thanks Meter: 81 | herewith is the fone and i need its piout connection iPhone 4 clone A8 with dual mode support*|  Cloned In China |
06-02-2012, 16:22 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! which connector has this phone? Iphone's 30pin? then you have to use same connector from infinity package. If you dont have in your set, it can be made by yourself or purchased separately |
06-03-2012, 17:54 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! you have to use first 24 pins of DB26 cable. they are marked 1-9, 10-18, 18-26. so it is easy to find needed 1-24. Iphone's connector has 30 pins. first type (A) cable you solder this way: DB26--------Iphone 1---------------1 2---------------2 3---------------3 4---------------4 5---------------5 6---------------6 7---------------7 8---------------8 9---------------9 11-------------11 12-------------12 13-------------13 14-------------14 15-------------15 16-------------16 17-------------17 18-------------18 19-------------19 20-------------20 21-------------21 22-------------22 23-------------23 24-------------24 |
06-03-2012, 17:59 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | As you can see, in "cable A" is covered only 24 pins from 30 available in Iphones connector. Now we have to make second cable, "cable B" to cover rest of pins: DB26--------Iphone 1---------------30 2---------------29 3---------------28 4---------------27 5---------------26 6---------------25 7---------------24 8---------------23 9---------------22 11-------------21 12-------------20 13-------------19 14-------------18 15-------------17 16-------------16 17-------------15 18-------------14 19-------------13 20-------------12 21-------------11 22-------------10 23-------------9 24-------------8 |
06-08-2012, 20:21 | #11 (permalink) |
Member: 22284 Status: Offline Thanks Meter: 81 | Thank i managed to format my ifone now its working and below is the log data READ GENERAL INFO Action: read/check information Model: _Autodetect MT6228-6276 NAND Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6235B, E0 Hardware version: KINGSTAR35_08B_HW Software version: MAUI.08B.W09.12.M22. Software date: 2000.00.00 Barcode: MT012345678901234567 CID: AT+READCID?ERROR Lock: AT+LOCKSTAT?ERROR imei-1: 358688000000158 Finished, time used: 3 sec Remove/Install battery now ! READ DETAILED INFO COM5 [VCP2] selected module v4.27 Device: _Autodetect MT6228-6276 NAND Checking data, wait... Action: read/check information interface: BROM_DLL_v3.1108.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8B00:8A00 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0028]: 0020:00F10000001D [ST] ST01GW3B chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (460800)... done interesting cpu type found: 6235:8B00:8A00 ram test (40000000)... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 04000000/04000000 firmware size: 64Mb ffs size: 64Mb detect sec ro... error:0BF9:S_DA_HANDSET_SEC_INFO_NOT_FOUND detect custom parameters... error:0401:S_CUST_PARA_NOT_SUPPORTED detect project-id... project-id: MAUI.08B.W09.12.M22.V14 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: KINGSTAR35_08B_BOOTLOADER_V005_MT6235B_MAUI_08B_W0 9_12_M22_V14.b nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: KINGSTAR35_08B_PCB01_GPRS_MT6235B_S01.MAUI_08B_W09 _12_M22_V14.BIN project-id: MAUI.08B.W09.12.M22.V14, 00000000 code offset: 00000000 ffs offset/size [01]: 04000000/04000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done Disconnect... done Finished, time used: 1 min 31 sec Remove/Install battery now ! READ FIRMWARE COM5 [VCP2] selected module v4.27 Device: _Autodetect MT6228-6276 NAND Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.1108.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8B00:8A00 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0028]: 0020:00F10000001D [ST] ST01GW3B chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (921600)... done interesting cpu type found: 6235:8B00:8A00 ram test (40000000)... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 04000000/04000000 firmware size: 64Mb ffs size: 64Mb detect sec ro... error:0BF9:S_DA_HANDSET_SEC_INFO_NOT_FOUND detect custom parameters... error:0401:S_CUST_PARA_NOT_SUPPORTED detect project-id... project-id: MAUI.08B.W09.12.M22.V14 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: KINGSTAR35_08B_BOOTLOADER_V005_MT6235B_MAUI_08B_W0 9_12_M22_V14.b nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: KINGSTAR35_08B_PCB01_GPRS_MT6235B_S01.MAUI_08B_W09 _12_M22_V14.BIN project-id: MAUI.08B.W09.12.M22.V14, 00000000 code offset: 00000000 ffs offset/size [01]: 04000000/04000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done area size: 64Mb number of areas/bytes to read: 1:04000000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... file saved: C:\Documents and Settings\Vin\Desktop\KINGSTAR35_08B_PCB01_GPRS_MT6 235B_S01.MAUI_08B_W09_12_ M22_V14__firmware_20120608-190145.B4M Disconnect... done Finished, time used: 60 min 42 sec Remove/Install battery now ! FORMAT FF COM5 [VCP2] selected module v4.27 Action: reset settings ("format ffs") Model: _Autodetect MT6228-6276 NAND Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8B00:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235B,E00 Date: 2000.00.00 Version: 1.0 Version: MAUI.08B.W09.12.M22.V14 Version: KINGSTAR35_08B_HW detecting structure #2... 1 2 4 5 8 9 11 12 done 88 byte(s) read imei: 35868800000015 connection Ok building list... done items total: 294 items to clear: 294 warning: wrong packet cs warning: wrong packet cs items cleared: 294 of 294 building list... done items remains: 0 Finished, time used: 1 min 29 sec Remove/Install battery now ! |
The Following User Says Thank You to chitawira For This Useful Post: |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
