12-07-2007, 12:18 | #1 (permalink) |
Junior Member Join Date: Nov 2007
Member: 624446 Status: Offline Thanks Meter: 5 | General mobile DST11 cant finilize testmode,need help please ps:this problem is for second pinouts,for the first one there is no problem working very well. COM9 [VCP8] selected Action: imei imei write method: mode-2 new imei: nnnnnnnnnnnnnn Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6205:8B00]... Connecting, wait... error: can't finalize test mide repeat operation and HOLD phone "Power" button long time ! Operation failed ! Finished, time used: 23 sec Remove/Install battery now ! |
12-07-2007, 20:33 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, Try to use keyboard codes to enable COM port (try different port values) and use imei repair "mode-1". Codes: http://www.atm-box.com/index.php?id=utilities |
12-10-2007, 13:16 | #5 (permalink) |
Member: 624446 Status: Offline Thanks Meter: 5 | COM8 [Serial2] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6205:8B00]... Connecting, wait... error: can't finalize test mide repeat operation and HOLD phone "Power" button long time ! Operation failed ! Finished, time used: 42 sec Remove/Install battery now ! |
12-10-2007, 14:33 | #6 (permalink) |
Member: 624446 Status: Offline Thanks Meter: 5 | COM8 [Serial2] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6205:8B00]... boot step size: 000A Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... slowest Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00700000 flash: 01227E22022201:18E59F00000000 checking area[00000000]: 00000000-007FFFFF... eeprom/ffs found near: 00700000 detecting eeprom/ffs size... eeprom/ffs size: 00100000 ffs chip: 00 eeprom/ffs area: 00000000:00700000-007FFFFF flash: 01227E22022201:18E59F00000000 Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... formatting... flash: 01227E22022201:18E59F00000000 Write Done Finished, time used: 48 sec Remove/Install battery now ! after this rest operation imei1 became 13579.. as expected,but imei2 completely lost. |
12-11-2007, 10:26 | #8 (permalink) |
Freak Poster Join Date: Apr 2004 Location: Antalya/Türkiye Age: 43
Member: 64224 Status: Offline Thanks Meter: 24 | DST11 write ok . file saved: C:\Documents and Settings\Halil ibrahim\Desktop\backup_eeprom_20071211-104458.B0E.bin flash: 01227E22202200:29EA0000000000 Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 Ok security area backup saved: id.68CD4015.[MTK26_05C_X11B_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_ 16.BIN_C8860F77].rpl identification#1 detection finished device-id: 68CD4015 identification#1 protocol ver: 04 ver. sw1: MTK26_05C_X11B_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_ 16.BIN ver. sw2: MAUI.05C.W06.16 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished security area#1 calculation file saved: backup_system_log_68CD4015_MTK26_05C_X11B_PCB01_GP RS_MT6226_S01.MAUI_05C_W06_16.BIN_C8860F77_2007121 1-104555.B0X.bin Area: Firmware flash: 01227E22202200:29EA0000000000 Write: Firmware Write Done file saved: backup_system_log_68CD4015_MTK26_05C_X11B_PCB01_GP RS_MT6226_S01.MAUI_05C_W06_16.BIN_C8860F77_2007121 1-111057.B0X.bin Finished, time used: 1782 sec Remove/Install battery now ! But i cant find anyway to second pinouts |
12-11-2007, 13:39 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! if none of infinity users willl reply- you can try to fond second pinout by yourself. connecting tx and rx to all free pins in all possible combinations. there is 12 pin connecotor with 4 pins known 3: Tx, 5: Rx, 6: Gnd, 12: Gnd. find where is battery pin also. this will give 5 known pins in total. so only 7 unknown pins- which give total tx/rx combinations just 42. can be tryed one by one less than in 20min |
12-11-2007, 17:31 | #10 (permalink) | |
Member: 64224 Status: Offline Thanks Meter: 24 | Quote:
i will miss my mind but thank you very much infinity team. i will try again and again . i will come br. ibocan | |
12-12-2007, 14:18 | #12 (permalink) | |
Member: 624446 Status: Offline Thanks Meter: 5 | Quote:
second pinouts:: 2:rx 4:tx br Last edited by gsmcodeman; 12-12-2007 at 14:25. | |
12-12-2007, 14:24 | #13 (permalink) |
Member: 624446 Status: Offline Thanks Meter: 5 | sorry forgot to post:after formatting and repiaring first imei,sim1 working fine as always but second sim does not show signal bar.finds network but no signal bar on screen.can make calls but cant accept call.when received a call i cant accept or reject,always ringing.can recive sms and also can send.there is sometinhg wrong with dst11.i also have factory software flash files etc. but i dont know chinese and i cant use that software |
12-14-2007, 12:27 | #14 (permalink) |
Member: 624446 Status: Offline Thanks Meter: 5 | latest situation:i flashed the phones with this file from support (GeneralMobile-DST11_MTK26_05C_X11TK_PCB01_GPRS_MT6226_S01.MAUI_0 5C_W06_16_16m_En_Tr_w_eeprom.B0M.bin).after flashing all functions working for both simcards.but when i repair the imei,tried with both methods,sim2 cant accept calls again and no network signal.i have 2 days left to do something,then i will return the phones to customer. br |
General Mobil DST11, Tinno DX11, LT X3 pinout, firmware upgrade and write 2 IMEI Help | odiseus | Infinity-Box | 5 | 12-18-2008 19:02 |
Need Flash File for GENERAL MOBILE DST11 or LT-X3 | toroslu | Multi-Box | 0 | 02-18-2008 21:52 |
pls help general mobile dst11 not charging ? | ferdi__can | Various | 0 | 01-12-2008 21:08 |
URGENT i needed general mobile DST11 pinout for flash write | abbaskil | Infinity-Box | 5 | 12-11-2007 13:59 |
