02-18-2017, 17:41 | #1 (permalink) |
Freak Poster Join Date: Apr 2010 Location: algeria Age: 48
Member: 1278921 Status: Offline Thanks Meter: 8 | help i can format or restor user oppo f1s if i try to flash the phone or hard reset shema doesnt delet Operation : Read Pattern/DP Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 518 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2122 EMICFG_NOT_ACCEPTED_CONFIG Boot Error! Operation Failed Elapsed: 00:00:15 Reconnect Power/Cable! |
02-18-2017, 18:15 | #4 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Hello, Press and hold vol+and - and connect if still same then its not supported,,, Wait until team Release MtkV2 |
The Following User Says Thank You to princesaddam For This Useful Post: |
