Old 09-06-2010, 08:40   #1 (permalink)
guru4gsm's Avatar
Member: 517316
Thanks Meter: 185
Help with INTEX-IN4495
Infinity team please help me with this Intex IN-4495 the problem is that i cant repair Imei of this set.
History - Set was restarting with sim card but without sim working OK, so i formatted it and now while repairing IMEI soft shows done........but when checking on mobile by *#06# it shows 000000000000.Aftre inserting sim cards it shows INVALID SIM.
Here are the logs......Detailed InFO
COM2 [VCP0] selected
module v3.09
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: read/check information
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:EF03:0009
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 2088C4FFFFFFFF:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
otp offset: 00FE0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
New firmware detected (v.3.09, database date: 16.02.2010):
DEWAV25_07B_GEMINI_Z868_PCB01_GPRS_MT6225_S00.INTE X_IN4495_Z808_Z808_L403_5M4.BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
rom info ver: 04
sw version: DEWAV25_07B_GEMINI_Z868_PCB01_GPRS_MT6225_S00.INTE X_IN4495_Z808_Z808_L403_5M4.BIN
project-id: INTEX_IN4495_Z808_Z808_L403_5M4, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00080000-00FFFFFF...
ffs/eeprom found near: 00E20000
Detected ffs/eeprom address is non-standard: 00E20000
Posible reasons:
1. ffs/eeprom is Ok but address is non-standard
2. ffs/eeprom is damaged and can't be detected
3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make full flash backup for emergency case
3. repeat required operation
Are you sure that detected ffs/eeprom address is correct ?
autodetected ffs/eeprom address confirmed by user: 00E20000
detecting ffs/eeprom size...
ffs/eeprom size: 001E0000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E20000-00FFFFFF
detecting ffs/eeprom structure pass 1...
detect standard ffs/eeprom location pass #1...
detect standard ffs/eeprom offset pass #1...
detect standard ffs/eeprom location pass #2...
detect standard ffs/eeprom offset pass #2...
detect standard ffs/eeprom location pass #3...
detect standard ffs/eeprom offset pass #3...
detect standard ffs/eeprom location pass #4...
detect standard ffs/eeprom offset pass #4...
ffs/eeprom record offset detected
detect standard ffs/eeprom data...
ffs/eeprom record size detected
ffs/eeprom layout detection complete
ffs/eeprom detected ok: element #1
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
detecting firmware version...
firmware version: DEWAV25_07B_GEMINI_Z868_PCB01_GPRS_MT6225_S00.INTE X_IN4495_Z808_Z8
detecting firmware build...
firmware build: TEX_IN4495_Z808_Z808_L403_5M4DEWAV25_07B_GEMINI_HW 2009-11-1317-27
detecting product-id...
done
detecting languages...
language parameters detected
detected languages: En Fr Hi Ar
Finished, time used: 1 min 30 sec
Remove/Install battery now !
Formatting Log
WARNING ! Settings will be cleared, user data erased, Imei set to default value !
Make flash backup before this procedure !
Do you want to continue ?
==== [9/4/2010 3:03:56 PM] ====
module v3.09
Action: reset settings ("format ffs")
Do you want to make ffs/eeprom backup before format ?
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize Done
====> Set baud ...
921600
Set baud Done
TCL-ID is absent
rom info ver: 04
TCL-ID is absent
Posible reasons:
ffs/eeprom chip: 00
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: DEWAV25_07B_GEMINI_Z868_PCB01_GPRS_MT6225_S00.INTE X_IN4495_Z808_Z808_L403_5M4__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\DEWAV25_07B_GEMIN I_Z868_PCB01_GPRS_MT6225_S00.INTEX_IN4495_Z808_Z80 8_L403_5M4__ffs_20100904-150548.B0E.bin
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 2 min 10 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Repair Imei........
Action: "repair imei"
Model: Autodetect 6205-6227 NOR
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
imei-1: 000000000000000
imei write method: mode-1
imei write channel: imei #1 for dual sim/mono CPU
new imei-1: 355256027097103
verification Ok
Finished, time used: 2 sec
Connecting, wait...
imei-2: 000000000000000
imei write channel: imei #2 for dual sim/mono CPU
new imei-2: 359443019554145
verification Ok
Connecting, wait...
Hardware version: MT6225, E05
Hardware version: DEWAV25_07B_GEMINI_HW
Software version: INTEX_IN4495_Z808_Z8
Software date: 2006.06.14
Barcode: MT012345678901234567
imei-3: 355256027097103
This firmware is missing in support area.So i can't flash with other firmware.....
I've sent full flash backup and eeprom backup to [email protected] for further research.
Old 09-06-2010, 08:44   #2 (permalink)
Member: 996359
Thanks Meter: 47
Did you tried 2nd method for repair imei ?
There are 3 methods to repair imei in infinty software
Old 09-06-2010, 09:37   #3 (permalink)
guru4gsm's Avatar
Member: 517316
Thanks Meter: 185
With other methods it keeps on restarting so I can't check........
I think its eeprom faulty or some bug in firmware.....!
Old 09-06-2010, 10:37   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
What do you mean "keeps restarting" ?
Is it restart during imei repair operation or after imei repair operation ?
Old 09-06-2010, 14:04   #5 (permalink)
guru4gsm's Avatar
Member: 517316
Thanks Meter: 185
After imei repair when we power on set...............
with or without sim card.
Then i again format it , it starts normally .
But after imei repair it keeps on restarting.
Hope it is clear now.
Old 09-06-2010, 14:32   #6 (permalink)
Member: 130995
Try to write the next imeis:
1. original imei from phone back label
2. 0000 (all zeroes) imei
Is it the same problem with these imeis (I mean restart after write) ?
Old 09-07-2010, 08:38   #7 (permalink)
guru4gsm's Avatar
Member: 517316
Thanks Meter: 185
yes it is the same problems with these imei's ..
I've tried all possible combinations in the soft like mode 1,2,3 and default imei inside firmware............
It shows imei write ok but when check (read general information)...look below......
Connecting, wait...
imei-3: 000000000000000
Finished, time used: 4 sec
Old 09-07-2010, 22:31   #8 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
can you find same working phone to read out full flash backup?
in this case you could Clone it
Old 09-08-2010, 14:46   #9 (permalink)
guru4gsm's Avatar
Member: 517316
Thanks Meter: 185
I'm looking for one but didn't find any ...........
If any of the members find same mobile please read Full flash and post here ..............
So that i can check it out and post results ..............
Thank You.
Old 09-08-2010, 18:08   #10 (permalink)
Member: 950629
Thanks Meter: 105
I also faced this problem with T33+.
I try various ways and finally full flash the phone but still same.
So I change the flash IC ,flash again and rebuild the imei.
It's work for me.
problem solved.
I think this is also a HW problem.
The Following 2 Users Say Thank You to mswmkm For This Useful Post:
Old 12-14-2010, 07:47   #11 (permalink)
cellexpert's Avatar
Member: 857876
Sonork: cellexpert-33
Thanks Meter: 63
no this is soft give readed eeprom i can give 1000000000% working eeprom contact
[email protected]
Old 12-14-2010, 10:57   #12 (permalink)
Member: 148515
[email protected]
hello!
upload to [url=http://www.rapidhsare.com/url] and post link here.
thank you in advance!
Old 02-09-2011, 11:52   #13 (permalink)
Registered User
Member: 1240431
Sonork: abhishek
Thanks Meter: 10
[email protected]
sir if you have intex 4495 eeprom backup, plz give me thanks in advance
[email protected]
Old 04-13-2011, 17:44   #14 (permalink)
gautamlondon's Avatar
Member: 186840
Thanks Meter: 103
I also have same problem of imei
pls if u got file then upload
Old 04-14-2011, 15:02   #15 (permalink)
Member: 186840
Thanks Meter: 103
why no answer from any one?
no solution?????????
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-1999 17:04
Page generated in 0.25170 seconds with 9 queries
