07-18-2008, 08:04 | #1 (permalink) |
No Life Poster Join Date: Sep 2004 Location: coast Age: 53
Member: 83397 Status: Offline Thanks Meter: 204 | Help Jmax 5700 Phone Code COM10 [VCP0] selected Device: J-Max-JM5700 Checking data, wait... Action: reset Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... error: can't run main loader: 8200 Finished, Remove/Install battery now ! Time used: 4 sec |
07-23-2008, 12:00 | #5 (permalink) |
Member: 83397 Status: Offline Thanks Meter: 204 | I did as you said but still not working as u can see log: COM10 [VCP0] selected Device: J-Max-JM5700 Checking data, wait... Action: reset Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... error: can't run main loader: Finished, Remove/Install battery now ! Time used: 5 sec |
07-23-2008, 12:34 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, try to use ordinary COM port cable (or other cable) due to several users had a problems with this phone connection as a result of cable problem. Also try to follow this instruction: C:\\Program Files\\InfinityBox\\Documentation\\Infinity-Box_How_to_fix_connection_problem_Moto-c113_c114_c115_c116_c117_c139.jpg |
09-26-2008, 12:15 | #12 (permalink) | |
Freak Poster Join Date: Sep 2007 Location: next to obama's ancestor grave
Member: 585028 Status: Offline Thanks Meter: 25 | Quote:
select zte 225 instead and unlock usercode. i have tested this and it works | |
pls help for gx10i phone code reset | bozan | Sharp | 9 | 11-23-2003 11:11 |
Please help to reset phone code! | Iviks | E-Gold Based Phones | 1 | 05-15-2003 23:15 |
Please, help with a50 phone code | yard | Phone Unlocking Codes & Maps | 0 | 04-16-2003 08:32 |
NEED HELP TO UNLOCK PHONE CODE ON c26 v61 | vladwork1974 | x1x to x45/x50 | 6 | 11-24-2001 10:48 |
NEED HELP TO UNLOCK PHONE CODE ON SL 45 | .:SkiR:. | x1x to x45/x50 | 1 | 11-15-2001 05:54 |
