05-09-2019, 04:36 | #3 (permalink) | |
Junior Member Join Date: Jul 2017
Member: 2732211 Status: Offline Thanks Meter: 4 | Quote:
Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... ERROR : Fail to init protocol! HINT : Check cable, connection and drivers! Reconnect Power/Cable! | |
05-09-2019, 07:24 | #4 (permalink) | |
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... BREAK : Device not found! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... ERROR : Fail to init protocol! HINT : Check cable, connection and drivers! Reconnect Power/Cable! | |
