Old 01-23-2010, 09:23   #1 (permalink)
iqballk's Avatar
Member: 13932
Sonork: 100.1609876
Thanks Meter: 411
Konka D316 repaired successful..
COM5 [VCP4] selected
module v3.03
Device: Konka-D363
Checking data, wait...
Action: reset settings ("format ffs") NAND
interface: BROM_DLL_v3.932.00
Connect...
Connecting...
Booting...
Release Power button now !
CPU: 6228:8A02:8A02
bbchip secure ver: FF
bbchip bl ver: FE
NOR flash chip: S_DA_NOR_FLASH_NOT_FOUND
warning: NOR flash chip is not installed
NAND flash chip: S_DONE
flash id[0007]: 00EC:00F100800015 [SAMSUNG] K9F1G08X0M
flash size: 128Mb
page/spare size: 0800/0040
pages/block: 0040
bits i/o: 08
address cycles: 04
internal RAM: S_DONE
external RAM: S_DA_DEVICE_NOT_FOUND
boot style: S_NAND_FLASH_BOOT
bootcode current/expected: 3.2, 3.2
done
Set baudrate (115200)...
done
ram test...
testing...
ram test passed
===> detect existing firmware structure...
detect ffs...
ffs offset/size: 02000000/06000000
firmware size: 32Mb
ffs size: 96Mb
detect sec ro...
detect custom parameters...
detect project-id...
project-id: KAB316_VIA_Vi_En_Ch_0.97.817
detect NAND info...
number of areas to read: 1
reading (HW_STORAGE_NAND)...
nfi area detection...
external bootloader is not present
bootloader version: D316VIA_BOOTLOADER_V005_MT6228_KAB316_VIA_VI_EN_CH _0_97_817.bin
nfi area detection finished: Ok
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
startup code area #1 is valid
startup code area #1 detection done
rom info ver: 04
sw version: D316VIA_PCB03_GPRS_MT6228_S02.KAB316_VIA_VI_EN_CH_ 0_97_817.BIN
project-id: KAB316_VIA_Vi_En_Ch_0.97.817, 99B16556
code offset: 00000000
ffs offset/size [01]: 02000000/06000000
rom info structure: 2nd [enhanced] generation
TCL-ID is absent
===> done
New firmware detected (v.3.03, database date: unknown):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
Format (HW_STORAGE_NAND)...
Disconnect...
done
file saved: D:\Program Files\InfinityBox\MModule\backup_security\Konka-D363_D316VIA_PCB03_GPRS_MT6228_S02.KAB316_VIA_VI_E N_CH_0_97_817__system_log_20100123-134746.B4X.bin
Finished, time used: 1 min 23 sec
Remove/Install battery now !
thanks infinity team.
regards..
The Following User Says Thank You to iqballk For This Useful Post:
Old 01-23-2010, 11:35   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Please, read full flash from this phone and send full flash bacjup file (or link) to [email protected]
Thank you !
K510 whitescreen repair success with REPAIR RED BLINK buton firmanbali Universalbox 1 10-13-2008 13:49
k800i repaired successfully (dead with cruiser) babbu Universalbox 13 06-30-2007 11:36
The 9 A9 D LOCK repairs successfully ll1221 Multi-Box 2 09-25-2006 04:52
About t191 repaired successfully by twister??? proxy_gsm Twisterflasher 1 02-12-2004 00:57
Page generated in 0.19347 seconds with 9 queries
