04-09-2008, 13:11 | #1 (permalink) |
Freak Poster Join Date: May 1999
Member: 52 Status: Offline Thanks Meter: 13 | Help needed for auto pin finder I just purchase the pin finder and activated. I follow the instruction first select com and detect adaptor and after that select cable type and plug in com cable and the power cable and press power on button on the software but the problem is the red light didn't appear state too many try. I unplug the power cable and press power off and power on again the red light appears and measure got 4v but if plug in cable red light diappear and no voltage. I smell from the infinity box it got smell like burning smell but i try to program using cable connect to PCB for N6500 it still can do formatting. Not sure is it the cause of it infinity box or the infinity pin finder adaptor? Please advice me please. Thank you very much. Best Regards Ian |
04-09-2008, 14:19 | #2 (permalink) |
No Life Poster Join Date: Nov 2005 Location: .:GSM WORLD:.
Member: 203158 Status: Offline Sonork: 100.1592032 Thanks Meter: 358 | Bro .. if u see the Manual u will never having the problems ... have u read the manual in pdf format .....???? if yes then tel me exactly what problem u are having???? cozz pinfinder is not so difficult o handle... |
04-09-2008, 16:53 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! please check user manual, there is exist some type of cables which need small modification before use. they have wrong pin grounded, so this makes shortcut. Does this happends with all cables or just with some? what is faulty cables names? |
04-10-2008, 04:54 | #4 (permalink) |
Member: 52 Status: Offline Thanks Meter: 13 | I am using L12B and line number 26 is not connected and only line number 9 is connected. So, I don't think is cable. I open the infinity box found out there is one VDD2(M7) is burn/crack, does it the cause of it? I check it in my country they don't have it, so I can't replace. Does it same with any other ? I do short it but still the same. Please advice me. Last edited by Ian; 04-10-2008 at 05:01. |
04-13-2008, 08:33 | #11 (permalink) |
Member: 52 Status: Offline Thanks Meter: 13 | Dear Sir, It is the main board for infinity box. Hope can repair it to have spare one. Today, I just purchase new inifinity box and with cable short, everything dtected fine. One question is should I need to short the board always or only when I use pin finder adaptor? Thank you very much |
Auto-Pin-Finder by Mr. SSP for Infinity-Box users | Miftahudin | Infinity-Box | 110 | 04-26-2009 17:42 |
help needed for 10 pin to 8 pin | FZA | MT-BOX | 1 | 03-17-2009 08:10 |
help me for infinity pin finder not actvataed | subhdra | Infinity-Box | 2 | 04-19-2008 09:52 |
Please Help me To Activating Infinity Auto Pin Finder | shinta | Infinity-Box | 2 | 02-13-2008 14:52 |
Infinity Box - Auto Pin Finder Adapter!!! | Hams | Main Sales Section | 0 | 02-09-2008 18:13 |
