12-07-2023, 13:07 | #1 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | Help with Tecno Spark 8C KG5K Code: Operation : Identify [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Tecno : KG5k Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Device info : Product Brand : TECNO Product Device : TECNO-KG5k Product Model : TECNO KG5k Product Name : KG5k Patch Level : RP1A.201005.001 Display ID : KG5k-F062-11.0-GL-V245-20230823 Ver. Incmt : GL-V245-20230823 Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2023-08-05 Build Time : 23.08.2023 Product Name : F062 Product Info : KG5k Product Board : KG5k Board Platform : ums9230 Product Manfct : TECNO MOBILE LIMITED USERDATA : FILESYSTEM : F2FS - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:00:43 Operation : Repair Security [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Tecno : KG5k Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! >>> Error : Device NOT INITIALIZED ! Initialize it first via "IDENTIFY" ! >>> Make sure you have made "IDENTIFY" first! Reconnect Power/Cable! |
12-07-2023, 17:34 | #2 (permalink) |
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | Device have baseband unknow but first, it had imei data ok, but no signal, I reflash and then baseband unknow... anyway to fix it please!!!! |
12-09-2023, 12:24 | #4 (permalink) |
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | Hello I did it, same , baseband unknow, when I tried to fix imei, always says Identify first, I did that, and then the same error, indentify first!!! |
