10-07-2021, 08:12 | #1 (permalink) |
No Life Poster Join Date: Jul 2010 Location: Uganda
Member: 1340870 Status: Offline Sonork: 1611357 Thanks Meter: 148 | Tecno kc8 spark 4 hang and restart ihave tried all files on support but this phone has failed to power on normally. what should ido. original file was this MT6761__TECNO_MOBILE_LIMITED__TECNO_KC8__9__KC8-H6110LMN-P-200617V205__PPR1.180610.011__kc8_h6110 itried this on support KC8-H6110LMN-P-201207V232 but phone failed to power on normally. |
The Following User Says Thank You to FREDDIE GTY For This Useful Post: |
10-07-2021, 08:20 | #2 (permalink) |
Member: 1340870 Status: Offline Sonork: 1611357 Thanks Meter: 148 | Card found : xxxxxx , v0150 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.28 Load IDBase v98353 Ok! Update configuration ... Update Ok! Load IDBase v98353 Ok! Operation : Identify [ v2.28 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM6) MODE : PRELOADER PORT PORT : 6 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : TECNO : SEC_MIXED | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 880103534C443332475507AE32241705 EMMC: VEN : FORESEE : OEM : 3 : ID : 534C44333247 EMMC: VEN : FORESEE : SLD32G EMMC: SNN : 128856612 ( 0x07AE3224) , MF : 1/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x73A000000 [ 28.91 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 263B8A0E2D6DDEEDA853E3AA5A060B7 DA : USB : HIGH-SPEED Boot done! USERDATA : EMPTY NVRAM : TK_MD_BASIC_MDBIN_PCB01_MT6761_S00.MOLY_LR12A_R3_M P_V71_11_P22 NVRAM : Damaged! Backup sensetive data [ 16 ] Backup path : Backup\MT6761__263B8A0E2D6DDEED0A853E3AA5A060B7\ [12] Read : NVRAM [37] Read : NVDATA [29] Read : PROINFO [13] Read : LK [36] Read : NVCFG [24] Read : PROTECT1 [25] Read : PROTECT2 [1] Read : PGPT [23] Read : PERSIST [0] Read : PRELOADER Backup done! STORAGE : Life Status : eMMC : NOT implemented in selected DA! STORAGE : OTP Status : UNLOCKED! Done! Elapsed: 00:00:28 Preloader [HW DEV] Info : EMI : DEV : MT6761 EMI : SRC : preloader_kc8_h6110.bin EMI : CNT : 000D EMI : [00] : DRAM : LP_DDR4 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 512.00 MB ] EMI : [01] : eMMC : DDR3 : ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 2.00 GB ] EMI : [02] : eMMC : DDR3 : ID : 150100464536324D42 : VEN : SAMSUNG | DEV : FE62MB : RAM : [ 1.00 GB ] EMI : [03] : DRAM : LP_DDR4 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] EMI : [04] : DRAM : LP_DDR4 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] EMI : [05] : DRAM : LP_DDR4 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] EMI : [06] : DRAM : LP_DDR4 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] EMI : [07] : DRAM : LP_DDR4 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] EMI : [08] : DRAM : LP_DDR4 : ID : 88 : VEN : FORESEE | DEV : : RAM : [ 1.00 GB ] EMI : [09] : DRAM : LP_DDR4 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] EMI : [0A] : DRAM : LP_DDR4 : ID : 70 : VEN : KINGSTON | DEV : : RAM : [ 1.00 GB ] EMI : [0B] : DRAM : LP_DDR4 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] EMI : [0C] : DRAM : LP_DDR4 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] Operation : Write Flash [ v2.28 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :22 [FL] : Set : preloader_kc8_h6110.bin [FL] : Set : md1img-verified.img [FL] : Set : spmfw-verified.img [FL] : Set : scp-verified.img [FL] : Set : scp-verified.img [FL] : Set : sspm-verified.img [FL] : Set : sspm-verified.img [FL] : Set : lk-verified.img [FL] : Set : lk-verified.img [FL] : Set : boot.img [FL] : Set : logo-verified.bin [FL] : Set : dtbo-verified.img [FL] : Set : tee-verified.img [FL] : Set : tee-verified.img [FL] : Set : vendor.img [FL] : Set : system.img [FL] : Set : vbmeta.img [FL] : Set : cache.img [FL] : Set : recovery.img [FL] : Set : tkv.img [FL] : Set : tranfs.img [FL] : Set : userdata.img [FL] : Total size : 0xC739E290 [ 3.11 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM6) MODE : PRELOADER PORT PORT : 6 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : TECNO : SEC_MIXED | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 880103534C443332475507AE32241705 EMMC: VEN : FORESEE : OEM : 3 : ID : 534C44333247 EMMC: VEN : FORESEE : SLD32G EMMC: SNN : 128856612 ( 0x07AE3224) , MF : 1/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x73A000000 [ 28.91 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 263B8A0E2D6DDEEDA853E3AA5A060B7 DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000009B00000 Erase : 0x000000000DB00000 : 0x00000000DAD00000 Erase : 0x00000000EC800000 : 0x0000000014D00000 Erase : 0x0000000101800000 : 0x0000000016280000 Erase : 0x0000000119A80000 : 0x00000000C4580000 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader backup copy ... Update bootloader backup copy Ok! Write : MD1IMG Write : SPMFW Write : SCP1 Write : SCP2 Write : SSPM_1 Write : SSPM_2 Write : LK Write : LK2 Write : BOOT Write : LOGO Write : DTBO FAIL : SEC : IMG TYPE MISMATCH Write : TEE1 Write : TEE2 Write : VENDOR Write : SYSTEM Write : VBMETA Write : CACHE Write : RECOVERY Write : TKV FAIL : SEC : IMG TYPE MISMATCH Write : TRANFS Write : USERDATA Ultra : OK! [ All failed parts successfully flashed ] SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:02:21 Reconnect Power/Cable! |
