Old 12-04-2016, 10:49   #1 (permalink)
Member: 946381
Thanks Meter: 150
COOLPAD 8298-100 IMEI BLANK-help
i did rebuild imei-logs ok as below-but still imei blank
Wait for phone...
Phone found! [ 24 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x93
NAND Flash : NOT INSTALLED
eMMC Flash : 484A01906532474181290705655E79A9
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , e2GA
[eMMC] : FLASH_CID : 90014A484147326505072981A9792365
[eMMC] : FLASH_LEN : 0x00000003AB800000
[eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB]
DEV RID : 0x76D40596FF761D8CBAA9C6C91AC545B8
INT RAM : 0x00020000
EXT RAM : 0xC0000000 [3 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
IMEI [00] : 357263047380400
IMEI [01] : 357263047380400
Set IMEI [00] : 911498056130887
Set IMEI [01] : 911498056130887
Prepare finished. Security check required!
Wait for phone...
Phone found! [ 24 ]
Sync...
Repair done!
Done!
Elapsed: 00:00:52
Reconnect Power/Cable!
""""""""""""""""still imei blank""""""""""""""""""""""
so i repaired fix unknown baseband and again repeat imei rebuild -logs ok-but still imei blank
so i think it software version problem-back sticker version 5.1.019 but menu version 15
"""""""i think must need 5.1.019 flash file""""am i right?
help me
Old 12-05-2016, 08:08   #2 (permalink)
Member: 946381
Thanks Meter: 150
supporters waitinggggggggggggg
Old 02-05-2018, 13:53   #3 (permalink)
Member: 1469862
Wait for phone...
Phone found! [ 24 ]
Sync...
Repair done!
Done!
Elapsed: 00:00:52
after go 2 seting facter rest ur phonw with ur sim
ur problam salou
Old 02-05-2018, 14:34   #4 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,551
HELLO @zone3, IT WILL NOT REPAIR BECOUSE OF DOWNGRADE YOU WILL NEED TO UPGRADE THE FIRMWARE AND YOUR PROBLEM WILL SLOVE
GOOD LUCK
Page generated in 0.13707 seconds with 8 queries
