06-12-2006, 09:42 | #1 (permalink) |
Freak Poster Join Date: May 2004 Age: 58
Member: 65419 Status: Offline Thanks Meter: 4 | how to enter NCK codes in Bird S299 i have readed the nck code of bird S299 but the problem is i cannot enter the codes as nothing appears on display of phone when i press the numbers.display shows nck locked, but cannot input the codes. is there any special code to enter first? help please here is the log COM2 selected Checking data, wait... Phone should be Switched OFF ! Connect... Press Power button now ! Connect Ok Boot... Boot Ok Read info... Flash ID: 8954 method: 02 Read info Ok Set baud... 115200 Set baud Ok Check flash... Check flash Ok Check space... In progress[EEP]... Active: NCK: 99624406 Inactive: PCK: 00000000 Finished Remove/Install battery now ! Time used: 33 sec brgds meneleo |
06-12-2006, 10:30 | #2 (permalink) |
Member: 65419 Status: Offline Thanks Meter: 4 | tried to flash the phone with firmware version 1.85, after flashing and inserted simcard, it still shows NCK Locked.any suggestion how i can enter the nck codes? before flashing, phone software version is 1.85 and i have read the flash. brgds meneleo |
06-13-2006, 02:39 | #3 (permalink) |
Freak Poster Join Date: May 2006 Location: neverland, WT 1982 Age: 42
Member: 279611 Status: Offline Thanks Meter: 4 | @ meneleo check your connection mate (comport, usb cable).. it works on me 100% check this out... Current device: S299 COM4 ready COM4 selected Checking data, wait... Phone should be Switched OFF ! Connect... Press Power button now ! Connect Ok Boot... Boot Ok Read info... Flash ID: 8954 method: 02 Read info Ok Set baud... 115200 Set baud Ok Check flash... Check flash Ok Check space... In progress[EEP]... Active: NCK: 27193133 Inactive: PCK: 00000000 Finished Remove/Install battery now ! Time used: 27 sec try to make some changes in your port settings... hope this will help you a bit... br... |
06-13-2006, 02:41 | #4 (permalink) |
Member: 279611 Status: Offline Thanks Meter: 4 | @ meneleo i-uploaded all the needed messenger here in the forum, check-out my uploads in the OFF TOPIC ZONE and feel free to download its absolutely free... |
06-13-2006, 08:24 | #5 (permalink) |
Member: 65419 Status: Offline Thanks Meter: 4 | thanks mate, but the only problem here is how can i enter this nck codes because only key 1,2 are working.other key is de activated.when i put not accepted sim card and phone on, it shows nck locked and you cannot type in any key except 1,2.however phone is working normally when original simcard is inserted. how do you enter the nck codes? what is the phone displays when you inserted not accepted simcard? is it nck locked? or nck codes? did you manage to unlock by just typing the nck codes? what is the phone version and did you flash it? best regards meneleo |
06-14-2006, 01:28 | #6 (permalink) |
Member: 65419 Status: Offline Thanks Meter: 4 | help infinity team sir, what should i do to enter this nck codes readed? as what ive said, keys are disabled except 1 & 2. do i need to send you the readed flashfile? there is no problem in reading nck codes in bird s299, but the question is how to enter this codes waiting for your help infinity team brgds meneleo |
06-15-2006, 22:53 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, We will try to modify our software to make it possible to reset blocked counter ASAP. Also if you have some free time you can try to find counter reset code from attached list (it's need to add "#" after code and it can be that it's need to press green button at end). Last edited by InfinitySupport; 06-22-2011 at 10:16. |
11-03-2006, 02:13 | #10 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: Inside facebook Age: 47
Member: 250468 Status: Offline Sonork: 100.110362 Thanks Meter: 96 | Quote:
01-08-2007, 09:24 | #14 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Mirpur-1, Dhaka,Bangladesh
Member: 222009 Status: Offline Sonork: 100.1576751 Thanks Meter: 435 | Yes I have done 1 pcs of that model by #*7337#. but it should be added to software a way to reset blocked counters |
How to Enter NCK Code for Bird S299 | kungpaoski | Infinity-Box | 2 | 04-21-2008 08:01 |
How to Enter NCK Code for Bird S299 | ASHRIFF | Infinity-Box | 0 | 08-23-2007 07:56 |
how to enter nck code in sendo s230 | ashvin | Various | 1 | 12-23-2005 16:48 |
how to enter nck code in lg u8360 ? | xxxs2060 | LG | 3 | 11-07-2005 00:40 |
How to enter NCK code in C1100 & C1200? | Windziarz | Blazer | 12 | 04-12-2005 16:01 |
