12-14-2009, 07:30 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: iSiddeque Age: 41
Member: 188260 Status: Offline Sonork: 100.1590438 Thanks Meter: 428 | How to flash Usha Lexus 838B ??? |
12-14-2009, 08:17 | #3 (permalink) | |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | Quote:
and i am and supporters here only for helping so please next time do more little wait !! BR Faisal_Computer | |
12-14-2009, 09:08 | #4 (permalink) | |
No Life Poster Join Date: May 2008 Location: COME & MADE GREEN WORLD
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | Quote:
& try to flash this file:-WP6226_PCB01_GPRS_MT6225_S00.B517_S32_OV70_K21_EN_ V008.BIN post result. | |
12-14-2009, 11:19 | #9 (permalink) | |
Member: 188260 Status: Offline Sonork: 100.1590438 Thanks Meter: 428 | Quote:
COM4 [VCP0] selected module v3.02 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware Usha-Lexus-838B_WP6226_PCB01_GPRS_MT6225_S00.B517_S32_OV70_K2 1_EN_V008_16m_En_Fr_Es_De_Th_Pt.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:E203:0009 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #02 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #03 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent ==================== New firmware detected (v.3.02, database date: 03.12.2009): WP6226_PCB01_GPRS_MT6225_S00.B517_S32_OV70_K21_EN_ V006.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info protocol ver: 04 ver. sw 1: WP6226_PCB01_GPRS_MT6225_S00.B517_S32_OV70_K21_EN_ V006.BIN ver. sw 2: B517.S32.OV70.K21.EN.V006, 00000000 code offset: 00000000 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: WP6226_PCB01_GPRS_MT6225_S00.B517_S32_OV70_K21_EN_ V006__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\WP6226_PCB01_GPRS _MT6225_S00.B517_S32_OV70_K21_EN_V006__ffs_2009121 4-145841.B0E.bin flash: 01227E22202200:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: 01227E22202200:18E59F00000000 Write: Firmware sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 2788 sec Remove/Install battery now ! | |
12-20-2009, 20:18 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, How to write flash (upgrade/downgrade firmware, change language): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to read flash: 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "Read flash" (or "Read full flash") button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not works try to make "complete" format (if this option exist) 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software |
how to flash a52? | fuadgsm | E-Gold Based Phones | 1 | 03-29-2010 18:48 |
How to flash SGH B520.-URGENT- | prashantvrm | Samsung Flashers, Software, Firmware. | 1 | 03-29-2010 13:24 |
how to flash e250i | adda2004 | Samsung Flashers, Software, Firmware. | 0 | 03-29-2010 12:26 |
Hello infinity team hear is i am read usha lexus 838b 100% ok set | debmobile | Infinity-Box | 2 | 09-28-2008 08:13 |
HELLO mr JACK-CHINA CAN YOU UPLOAD THIS READED 100% OK SETFILE MODEL USHA LEXUS 838B. | debmobile | SpiderMan | 1 | 09-26-2008 16:11 |
