Member: 840762
Thanks Meter: 166 | How to read firmware without DA and sSLA? Hi Team,
How to read fw in new phones?
I make backup data: Quote:
Operation : Identify [ v2.21 ]
Mode : FLASH
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port_V1632 (COM28)
MODE : BOOTROM
PORT : 28
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
CODE : Cervino
TYPE : MODERN RAPHAEL
BROM : MEID : 8DDFA5BA33E8758FFF37070FFB3501CB
BROM : SecLevel : 0x000000E7
BROM : SecMode : SBC+SLA+SDA+EXT
BROM : BROM|BL : 0x05|0xFE
BROM : BOOTROM
MODE : 0_base : BASE_v2044 | Manual : Disabled
BROM : SOCID : 2842AC993B2BDC30E1EBD7FCA015AC8B8B0BBF32D445049AA3 417BB36D7EF910
BROM : SLA : Local Auth
BROM : SLA : Auth Started!
BROM : SLA : Auth Passed!
BROM : SLA : 0x0000001F
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6765
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : DEV : INFINITY
EMI : SRC : PRELOADER_INFINITY_0
EMI : CNT : 0001
EMI : Init EMI from INTERNAL DB
EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x0003A000 [ 232,00 KB ]
DRAM: 0x100000000 [ 4,00 GB ]
EMMC: 150100445636444D420296EBCC38B7DF
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : DV6DMB
EMMC:
BOOT1 : 0x00400000 [ 4,00 MB ]
BOOT2 : 0x00400000 [ 4,00 MB ]
RPMB : 0x01000000 [ 16,00 MB ]
USER : 0x1D1EC00000 [ 116,48 GB ]
CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : DEB832952CF3593329AE3D0627BBA2AC
DA : USB : HIGH-SPEED
Boot done!
Patch Level : QP1A.190711.020
Display ID : QP1A.190711.020 release-keys
Ver. CodeName : REL
Ver. Release : 10
Sec. Patch : 2020-11-05
Build Time : 24.11.2020
Product Board : MT6765
Board Platform : mt6765
USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption )
NVRAM check : Passed!
NVRAM : SEC NORMAL [ No extra security ]
Backup sensetive data [ 15 ]
Backup path : Backup\MT6765__DEB832952CF3593329AE3D0627BBA2AC\
Backup done!
STORAGE : LifeStatus : eMMC : OK!
Done!
Elapsed: 00:00:21 | But read fw not work: Quote:
Operation : Read Firmware [ v2.21 ]
ExtSparse : Enabled
ForceRead : Disabled
MODE : BOOTROM
PORT : 28
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 0001
EMMC:
Boot done!
Ver. CodeName : REL
Ver. Release : 10
MT6765__10__QP1A.190711.020
Unsupport : 0x0000000003000000 : 0x0000000002000000 : recovery2
Error : Device NOT supported for SAFE READ!
>>> Send log and report.log (if exists) to support! Include device info also!
Reconnect Power/Cable!
| I try make hw report: Quote:
Operation : HW Report [ v2.21 ]
HWreport : Mode : eMMC
MODE : BOOTROM
PORT : 28
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 0001
EMMC:
Boot done!
Memory Info :
CID : 150100445636444D420296EBCC38B7DF
MEM : VEN : SAMSUNG | OEM : 01 | DEV : DV6DMB
DAT : Size: 119276 MB, Max.Speed: 52000 kHz, blklen(512), nblks(244277248), ro(0)
EXT_CSD Info :
EXT_CSD rev. : v1.8 ( MMC v5.1 )
CSD struct rev. : v1.2
Supported command sets : 1h
HPI features : 1h
BG operations support : 1h
BG operations status : 0h
Correct prg. sectors : 0h
1st init time after part. : 3000 ms
Min. write perf.(DDR,52MH,8b): 0h
Min. read perf. (DDR,52MH,8b): 0h
TRIM timeout: 0 ms
Secure feature support: 55h
Secure erase timeout : 8100 ms
Secure trim timeout : 5100 ms
Access size : 3584 bytes
HC erase unit size : 512 kbytes
HC erase timeout : 300 ms
HC write prot grp size: 8192 kbytes
HC erase grp def. : 0h
Reliable write sect count: 1h
Sleep current (VCC) : 7h
Sleep current (VCCQ): 7h
Sleep/awake timeout : 26214400 ns
Sector count : e8f6000h
Min. WR Perf. (52MH,8b): 0h
Min. Read Perf.(52MH,8b): 0h
Min. WR Perf. (26MH,8b,52MH,4b): 0h
Min. Read Perf.(26MH,8b,52MH,4b): 0h
Min. WR Perf. (26MH,4b): 0h
Min. Read Perf.(26MH,4b): 0h
Power class: 0
Power class(DDR,52MH,3.6V): 0h
Power class(DDR,52MH,1.9V): 0h
Power class(26MH,3.6V) : 0h
Power class(52MH,3.6V) : 0h
Power class(26MH,1.9V) : 0h
Power class(52MH,1.9V) : 0h
Part. switch timing : 2h
Out-of-INTR busy timing: ah
Card type : 57h
Command set : 0h
Command set rev.: 0h
HS timing : 0h
Bus width : 0h
Erase memory content : 0h
Partition config : 48h
Boot partition size : 4096 kbytes
Boot information : 7h
Boot config protection: 0h
Boot bus width : 2h
Boot area write prot : 0h
User area write prot : 0h
FW configuration : 0h
RPMB size : 16384 kbytes
Write rel. setting : 1fh
Write rel. parameter: 14h
Start background ops : 0h
Enable background ops: 2h
H/W reset function : 1h
HPI management : 0h
Max. enhanced area size : 1369h (40706048 kbytes)
Part. support : 7h
Part. attribute: 0h
Part. setting : 0h
General purpose 1 size : 0h (0 kbytes)
General purpose 2 size : 0h (0 kbytes)
General purpose 3 size : 0h (0 kbytes)
General purpose 4 size : 0h (0 kbytes)
Enh. user area size : 0h (0 kbytes)
Enh. user area start: 0h
Bad block mgmt mode: 0h
Overall status :
MLC status : 0% - 10% used
SLC status : 0% - 10% used
EOL status : Normal ( Less than 80% reserved blocks used )
RPMB : RPMB KEY EXISTS! [State : NOT CLEAN : UNUSABLE]
Done!
Elapsed: 00:00:24
| Any way for read fw?
BR |
