How to repair PinFinder find pin, flash, read flash, format (but only full format, safe no) working fine with pifinder, but repair imei with mode #1-#2 and safe format not working, after press power button mobile only blink and turned off. mobile not turned on with pinfinder. how to repair this problem? |
hello! you must modify main infinity box. diode must be removed there, this will deliver more power to pinfinder, which in own turn will make Test mode operations work better. procedure is described in Pinfinder User Manual, trubleshooting section |
same problem. http://s44.radikal.ru/i103/1004/02/2659a5c7f930.jpg |
try to use external power supply, find pinouts as usual for test mode operations 1. adjust power supply voltage to 4.2v 2. connect pinfinder to phone using data cable. 3. connect pinfinder's black power cable to phone's - (ground) battery pin. (no connection of pinfinder's red power connetor) 4. connect power supply also to phone's battery pins (both + and -) now u can do test mode operations without power problems br. |
another method to give external power after pinout is found 2 Attachment(s) hello! you can attach battery to free pair of crocodiles or you can use phone battery, but you have to connect GND pin to some phone grounded part I am attaching examples |
hi my pinfider is creating pro. only find pin ,read flash format imei no working just show hold power button when i hold it then set is on i check port it,s com2 port is ok what is problem plzzzzzzzz help sir....... |
today i use pinfider my pinfider is ok i have LGRD10000 CDMA phone it was 18 pin connector and i use qualcomm cpu base select and click on find pin pin find sucessfully but when set info by using other soft then not show esn no now on spot i use kg800 usb cable insert in this time when i facing this pro. only find pin rx tx ,read flash format imei no working any function just show hold power button when i hold it then set is on when i read general information then loading blue color show Connecting, wait... and blue line is very fastly ending only 4 sec i changte autobaudrate when line wait 20-25 sec but phone not conncted show i check port it,s com2 port is ok what is problem plzzzzzzzz help sir....... |
hello! please show all logs. take one Chinese phone, find its pinout and next try to do software operations. post here both logs (pinfinder and Chinese Miracle) |
