04-21-2010, 09:54 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Georgia GE
Member: 162473 Status: Offline Sonork: Not have Thanks Meter: 592 | How to repair PinFinder how to repair this problem? |
04-21-2010, 21:52 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,536 | hello! you must modify main infinity box. diode must be removed there, this will deliver more power to pinfinder, which in own turn will make Test mode operations work better. procedure is described in Pinfinder User Manual, trubleshooting section |
04-22-2010, 06:01 | #3 (permalink) | |
Member: 162473 Status: Offline Sonork: Not have Thanks Meter: 592 | Quote:
same problem. | |
The Following User Says Thank You to IkaMazini For This Useful Post: |
04-22-2010, 06:41 | #4 (permalink) |
No Life Poster Join Date: Nov 2003 Location: srilanka Age: 51
Member: 44229 Status: Offline Sonork: 1592530 Thanks Meter: 366 | try to use external power supply, find pinouts as usual for test mode operations 1. adjust power supply voltage to 4.2v 2. connect pinfinder to phone using data cable. 3. connect pinfinder's black power cable to phone's - (ground) battery pin. (no connection of pinfinder's red power connetor) 4. connect power supply also to phone's battery pins (both + and -) now u can do test mode operations without power problems br. |
The Following User Says Thank You to gsmbac For This Useful Post: |
04-22-2010, 07:24 | #5 (permalink) | |
------------------------ Last edited by IkaMazini; 04-22-2010 at 07:34. | |
04-22-2010, 21:32 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,536 | another method to give external power after pinout is found hello! you can attach battery to free pair of crocodiles or you can use phone battery, but you have to connect GND pin to some phone grounded part I am attaching examples |
04-23-2010, 07:34 | #7 (permalink) | |
09-01-2010, 18:17 | #8 (permalink) |
Freak Poster Join Date: Oct 2006 Location: love in your heart
Member: 373527 Status: Offline Thanks Meter: 68 | hi my pinfider is creating pro. only find pin ,read flash format imei no working just show hold power button when i hold it then set is on i check port it,s com2 port is ok what is problem plzzzzzzzz help sir....... |
09-01-2010, 18:32 | #9 (permalink) |
Member: 373527 Status: Offline Thanks Meter: 68 | today i use pinfider my pinfider is ok i have LGRD10000 CDMA phone it was 18 pin connector and i use qualcomm cpu base select and click on find pin pin find sucessfully but when set info by using other soft then not show esn no now on spot i use kg800 usb cable insert in this time when i facing this pro. only find pin rx tx ,read flash format imei no working any function just show hold power button when i hold it then set is on when i read general information then loading blue color show Connecting, wait... and blue line is very fastly ending only 4 sec i changte autobaudrate when line wait 20-25 sec but phone not conncted show i check port it,s com2 port is ok what is problem plzzzzzzzz help sir....... |
09-01-2010, 20:46 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,536 | hello! please show all logs. take one Chinese phone, find its pinout and next try to do software operations. post here both logs (pinfinder and Chinese Miracle) |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
