Old 09-21-2020, 11:04   #1 (permalink)
aminnovelty's Avatar
Member: 566122
Thanks Meter: 322
How to reset frp of infinix x-625c ?
Dear sir i got infinix hot 7 pro for reset FRP ,,,i search a lot but could not found any DA file to connect this set ,,,kindly guide me HOW TO RESET FRP BY CMTK2 ver 2.15 ?
Waiting for kind replies ,,,
Old 09-21-2020, 15:41   #2 (permalink)
Member: 566122
Thanks Meter: 322
Anybody or kind supporter can give me the DA file for infinix X-625C ? need only valid link without password ,,,,if anybody can help in this regard ...
Old 09-21-2020, 15:52   #3 (permalink)
Member: 2452939
Thanks Meter: 256
Select model infinix, New Sec
Reset frp in Preloader mood..
Other one
Select Tecno, Lb6
Reset frp.
Post the result.
The Following User Says Thank You to GSM SINDH For This Useful Post:
Old 09-21-2020, 15:55   #4 (permalink)
babarmughal's Avatar
Member: 2609063
Thanks Meter: 103
if not done, then post logs here.. i will give you DA
The Following User Says Thank You to babarmughal For This Useful Post:
Old 09-21-2020, 18:01   #5 (permalink)
Member: 2955840
Thanks Meter: 83
Always use search button for quick answer to anything. X625c da in support. https://forum.gsmhosting.com/vbb/f29...86/index3.html
The Following User Says Thank You to Chijohn For This Useful Post:
Old 09-22-2020, 07:14   #6 (permalink)
Member: 566122
Thanks Meter: 322
I am using ver 2.15 where is
Load IDBase v714150 Ok!
i cant find ,,,please guide enable to reset phone X-625c...infinix.
Old 09-22-2020, 07:17   #7 (permalink)
Member: 566122
Thanks Meter: 322
just need DA file and nothing else ,,,if anybody can help.
Old 09-22-2020, 07:21   #8 (permalink)
Member: 566122
Thanks Meter: 322
Know phone is DEAD ,,,will be ok if i will get DA file for said model ,,,anybody there to understand and help me ,,, here is log file -:
Card found : D11790A9 , v0145
Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.15
Load IDBase v729152 Ok!
Operation : Identify [ v2.15 ]
Mode : FLASH
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
Device not found!
>>> Check cable, battery, connection and drivers!
Reconnect Power/Cable!
Mode : FLASH
PTFN : PreLoader USB VCOM Port (COM13)
MODE : PRELOADER PORT
PORT : 13
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
CHIP : MT6757 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001
CODE : Kibo
TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x00000005
BROM : SecMode : SBC+SDA
BROM : BROM|BL : 0xFF|0x02
BROM : PRELOADER PORT
MODE : TECNO : LB6 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : DA_SWSEC.bin
AGENT : Selected AGENT doesn't have required configuration!
>>> Check and select CORRECT SETTINGS for your device!
Operation : Reset Settings/Format FS [ v2.15 ]
Mode : FRP [ RESET PROTECTION ]
PORT : 13
PRELOADER : ACK confirm FAIL!
BROM : Init BROM
BROM init passed!
CODE : Kibo
MODE : INFINIX : SEC_NEW | Manual : Disabled
AGENT : MTK_AllInOne_DA.bin
Old 09-22-2020, 07:50   #9 (permalink)
Member: 566122
Thanks Meter: 322
Once again i try to set check on ENABLE then took info ,,,surprisely my phone becomes ALIVE ,,,but problem is still there to for resolve ,,,
Old 09-22-2020, 08:04   #10 (permalink)
Member: 566122
Thanks Meter: 322
baba i will be realy gratefull you ,,if you could kindly give me DA file for said model ,,,this forum is made with concept to learn and help each other .... but remember sir ,,,file should not be password protect,,, i have download 3 DA file since tomorrow from different link but all are password protected ,,,, hope you will not feel it. waiting for your knd help.
Old 09-22-2020, 08:57   #11 (permalink)
Member: 566122
Thanks Meter: 322
i hope atleast any single member or kind suppoter of this valued product will help me to five DA file ,,,,still awaiting ,,,
Old 09-22-2020, 17:20   #12 (permalink)
Member: 2452939
Thanks Meter: 256
If you follow these methods so really no need any kind of da files because infinity team already made everything in software as I said you above
You can read again here
In main platform
Other one
Select Tecno, Lb6, or secure v2
Reset frp.
And Post the result.
Old 09-22-2020, 17:31   #13 (permalink)
Member: 2609063
Thanks Meter: 103
okie fine... here is your DA
how to use,
paste in TECNO folder location.... C:\InfinityBox\CM2MT2\boot\Tecno
now open MT2 tool and click on TECNO DA... you will find last bottom X625C
just select it and do what you want.
Enjoy.
link is here. X625C
without password
The Following 3 Users Say Thank You to babarmughal For This Useful Post:
Old 09-22-2020, 17:36   #14 (permalink)
Member: 2609063
Thanks Meter: 103
just use and post logs/result here brother.
Old 09-23-2020, 06:57   #15 (permalink)
Member: 566122
Thanks Meter: 322
how to use,
Enjoy.
link is here. X625C
without password
Forum rules doesnt allow me ,,,otherwise i wanna to pay you thanks personaly from the bottom of my heart,,,love you baba.
The Following User Says Thank You to aminnovelty For This Useful Post:
Page generated in 0.24462 seconds with 8 queries
