11-21-2008, 16:55 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Age: 48
Member: 107916 Status: Offline Thanks Meter: 30 | How to unlock this alcatel S210 i have one lock alcatel S210, when i try to unlock it i just have this message ; COM6 [VCP0] selected module v1.28 Device: Alcatel-S211 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: DB4F Connecting... booting... finalizing... Boot fail Finished, time used: 60 sec Remove/Install battery now ! please how can i unlock it regards leroi |
11-21-2008, 16:57 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, It looks like it's cable problem (rom version can not be detected well at initial boot step), please, double check cable and try again several times. |
11-21-2008, 16:58 | #3 (permalink) | |
Member: 107916 Status: Offline Thanks Meter: 30 | Quote:
COM6 [VCP0] selected module v1.28 Device: Alcatel-S210 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: FB3F Connecting... booting... finalizing... Boot fail Finished, time used: 68 sec Remove/Install battery now ! please i need your help | |
11-21-2008, 17:04 | #4 (permalink) |
11-21-2008, 17:06 | #5 (permalink) |
Member: 107916 Status: Offline Thanks Meter: 30 | Dear thanks for your help i sucessfully unlock it by changing cable, using C2500 infinity cable§ COM6 [VCP0] selected module v1.28 Device: Alcatel-S210 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection... Check connection done Set baud... 812500 Set baud done Check hardware... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data... reading Alcatel-S210_eeprom_calibration-1... file saved: D:\Program Files\InfinityBox\HModule\Alcatel-S210_eeprom_calibration-1_20081121-170307.80E.bin Read data done Check data... Check data done Writing... ......... ......... ... flash: 012A7E2A242A00:54000000000000 Write: simlock Writing done Finished, time used: 69 sec Remove/Install battery now ! regards leroi |
11-21-2008, 17:20 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
11-22-2008, 05:36 | #7 (permalink) |
Freak Poster Join Date: Apr 2006 Location: I N D I A Age: 39
Member: 262429 Status: Offline Thanks Meter: 123 | S210 permanently blocked phone Hi how to unlock permanently blocked phone alcatel s210, i unlcok with infinity unlock show unlock successful, but phone shows bloked permanently, how to solve pls guide me . Thx in adv, |
11-23-2008, 07:26 | #9 (permalink) |
Member: 262429 Status: Offline Thanks Meter: 123 | here is th log for alcatel s210 blocked perm.. COM3 [VCP0] selected module v1.29 Device: Alcatel-S210 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection... Check connection done Set baud... 812500 Set baud done Check hardware... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data... reading Alcatel-S210_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-S210_eeprom_calibration-1_20081123-115256.80E.bin Read data done Check data... Check data done Writing... ......... ......... ......... .. already unlocked Writing fail error: operation failed Finished, time used: 63 sec Remove/Install battery now ! this log is 2nd time unlock procedure, phone imei -352409022339185 any solution? |
11-23-2008, 13:51 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If phone can not be unlocked after unlock process via software we have no other methods to unlock it yet. Anyway, please, post here exact text that you can see at phone LCD when you power-on it with sim card so we will be able to check it for future research. Thank you ! |
11-24-2008, 05:09 | #11 (permalink) | |
Member: 262429 Status: Offline Thanks Meter: 123 | when power-on it with sim card error was-(Blocked permanently call operator), thx, in adv, Quote:
12-28-2008, 18:51 | #14 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
01-29-2009, 06:55 | #15 (permalink) |
Freak Poster Join Date: Jul 2005 Location: pondicherry,INDIA Age: 47
Member: 165982 Status: Offline Thanks Meter: 71 | successfully unlocked alcatel s210.thanks to infinity team COM37 selected module v1.30 Device: Alcatel-S210 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-S210_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-S210_eeprom_calibration-1_20090127-190533.80E.bin Read data done Check data ... Check data done Write ... ......... ......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Write done Finished, time used: 78 sec Remove/Install battery now ! |
The Following User Says Thank You to barani For This Useful Post: |
How To Unlock E101 Alcatel ? | y_info2004 | Easy-Unlocker | 7 | 01-15-2008 20:55 |
how to unlock a alcatel c560 | juvenile | FuriousGold | 1 | 01-12-2008 10:02 |
Can someone please tell how to unlock my alcatel 159? | sidiki | Alcatel TCL Phones and New Models | 0 | 07-29-2007 21:19 |
how to unlock?? new alcATEL PHONES... | saidgoren | Alcatel TCL Phones and New Models | 12 | 06-13-2006 11:41 |
how to unlock 525 Alcatel | chip_2000 | BF, BG, TH, BHx Series | 1 | 05-08-2003 12:59 |
