11-08-2006, 02:32 | #1 (permalink) |
Insane Poster Join Date: Nov 2005
Member: 196633 Status: Offline Thanks Meter: 8 | How to use Infinity Box Repair Feature I have a Moto C139 from tracphone. S.W. Ver 8.5.17. Tried to Flash each set of Firmware + Flex one by one via Infinity Box found in the support area in order to find best solution for both Cingular and T-mobile. When I flash the below set C139_1.0.24_Main C139_1.0.24_Flex_FFN_4R_10X C139_1.0.24_LPN_NA2_00X_Fr_EsLA and choose SERVICE-> SP-UNLOCK, result as below SW ver: 1.0.24 HW ver: MOTOROLA_E88 LP ver: LPN_C139_NA_T0H Flex ver: FFN_C139_4R_10X Check Flash-1 Done Check Flash-2... In progress... file saved: Backup_eeprom-1__2006-11-7_16-25-19.31E.bin Err: non-locked or unknown eeprom Check Flash-2 Fail Finished Remove/Install battery now ! Time used: 14 sec The phone dead Tried to repair using infinity box REPAIR MODULE with out success. Boot... Phone should be Switched OFF ! Press Power button now ! Err: boot error[02] Boot Fail Finished Remove/Install battery now ! Time used: 51 sec The phone can NOT connect to the box Question - Can I repair the phone using infinity box? - How to repair if above question is YES Thanks and BR Diesel |
11-08-2006, 03:22 | #2 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Philippines Age: 64
Member: 173878 Status: Offline Thanks Meter: 295 | first of all, you did not read the procedure on how to unlock this model. How to unlock C261 TracFone 1. Make backup (read flash) for emergency case 2. Flash phone with the 0.1.32 set of files from support area 3. Make “Unlock” |
11-08-2006, 05:25 | #5 (permalink) | |
No Life Poster Join Date: Oct 2004 Location: CAIRO _ @ _ 112 _ -= EMERGENCY ROOM =- Age: 48
Member: 86655 Status: Offline Thanks Meter: 385 | sure you can make it at first did you make backup? Quote:
waiting your answer @donex74 i think you must be sure what you say coz smartclip can't repair c139 at all untill now is only can unlock the old .v | |
11-08-2006, 10:07 | #7 (permalink) | |
At first, please, describe what you tried to do with phone in fact ! It's need to know all your operations in details because in your current description exist small mistake. It's IMPOSSIBLE to make any damage for phone during unlock procedure ! So, after I check your description of problem I see that you made WRONG description ! Phone CAN'T be dead after unlock try. Phone can be dead only after wrong flashing (wrong files selected or empty battery). So, make this: 1. make correct honest description of all your operations ! 2. check battery voltage and charge battery if need 3. try to flash phone again 4. if phone can't be flashed anymore: use "RepairModule", cut track, make "repair" procedure, restore track, flash phone with ordinary firmware and phone alive and unlocked. | |
11-08-2006, 10:32 | #8 (permalink) |
Member: 196633 Status: Offline Thanks Meter: 8 | Thank you for you reply. I am not quite sure what leads to "dishonest" but I am trying to make it clear Let make it short 1. I flashed (this file is for a SP called Cingular) C139_1.0.24_Main C139_1.0.24_Flex_FFN_4R_10X C139_1.0.24_LPN_NA2_00X_Fr_EsLA 2. I unplug phone, loose the battery, reinstall the battery, re-plug the phone on to unlocking cable 3. I choose SERVICE-> SP-UNLOCK below quote from log file SW ver: 1.0.24 HW ver: MOTOROLA_E88 LP ver: LPN_C139_NA_T0H Flex ver: FFN_C139_4R_10X Check Flash-1 Done Check Flash-2... In progress... file saved: Backup_eeprom-1__2006-11-7_16-25-19.31E.bin Err: non-locked or unknown eeprom Check Flash-2 Fail Finished Remove/Install battery now ! Time used: 14 sec 4. I unplug the phone, remove battery, reinstall battery. and find the phone can NOT turn on 5. I double checked the battery, it's good 6. I tried to reflash the phone without succcess. The phone can NOT connect to the BOX. Another backgound info. is, the phone make weak click sound when I press the power button as the BOX told me to do so. 7. Full log file available for check upon request. Thanks again and BR Diesel |
11-08-2006, 10:54 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, I am sure that it's can't be any phone damage after step-4. It's impossible becase at step-4 it was made no any action with phone, only information reading that can't damage your phone. So, double check the next: 1. battery. what is battery voltage now ? 2. cable 3. phone hardware |
11-08-2006, 11:25 | #10 (permalink) |
Member: 196633 Status: Offline Thanks Meter: 8 | Hi, 1. Voltage = 3.81 V unloded / shows full 3 bars on the phone 2. Cable's good In order to make test, I use same battery and cable to load Firmware etc. on the second phone, result is good. After SP-UNLOCK, second phone dead. This happens 5 mins ago. No way hardware failure again, right Again please allow me say it. when press the power button on the dead phone, it clicks once every 3 seconds. If you feel necessary, I can mail the dead phone, and volunteer a good phone for you to test. Thanks Diesel |
11-08-2006, 11:42 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, I can't beleive that after unlock phone ver 1.0.24 you can have any problems and phone can't be flashed again. Please, send operation.log file to me: [email protected] |
11-09-2006, 08:57 | #13 (permalink) |
Member: 196633 Status: Offline Thanks Meter: 8 | Dead phone come back to alive using moto01 V1.27 1. dead phone can hook up to the box 2. load firmware + Flex+ Langpack -> success 3. Boot the phone success -> success 4. SP-Unlock -> failure 5. Phone still alive Good job infinity team! |
11-09-2006, 10:41 | #15 (permalink) |
No Life Poster Join Date: Jul 2004 Location: YODAFON
Member: 75392 Status: Offline Sonork: 100.81199 Thanks Meter: 136 | @Diesel, new Bee , check your cable dude, I had cable problem too, and I colden my ***** and disturbed Infinity Team few days for nothing.... |
How to use Infinity-Box PinFinder with jaf | miguel_luo | Infinity-Box | 6 | 06-29-2012 10:05 |
how to use infinity box and infinity apf box plus | wahablepirate | Infinity-Box | 10 | 06-14-2012 17:27 |
how to use infinity-box | cinamania | Infinity-Box | 5 | 04-05-2009 08:24 |
how to use infinity box | sajjadahmad | Infinity-Box | 1 | 03-21-2008 06:31 |
How to use Infinity box | zakir375 | Infinity-Box | 2 | 08-01-2007 09:12 |
