Member: 2958962
Thanks Meter: 28 | Oppo A15 CPH2185 Boot Done but smart reset failed Quote:
Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.20
Load IDBase v125162 Ok!
Operation : HW Report [ v2.20 ]
HWreport : Mode : eMMC
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port_V1632 (COM27)
MODE : BOOTROM
PORT : 27
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
CODE : Cervino
TYPE : MODERN RAPHAEL
BROM : MEID : AA7783F2AF7B257EFFA5F144D843657A
BROM : SecLevel : 0x000000E5
BROM : SecMode : SBC+SDA+EXT
BROM : BROM|BL : 0x05|0xFE
BROM : BOOTROM
MODE : 0_base : BASE_v2044 | Manual : Disabled
BROM : SOCID : 8F9CB31E12D223170B9CCC1E6FD941FFABC9F860BE948E823A 08F6A20C4EB5A7
BROM : SLA : Local Auth
BROM : SLA : Auth Passed!
BROM : SLA : 0x0000001F
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6765
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : DEV : INFINITY
EMI : SRC : PRELOADER_INFINITY_0
EMI : CNT : 0004
EMI : Init EMI from INTERNAL DB
DA : SETUP EMI PARAMS FAILED!
ERROR : ABORT
Boot done!
Memory Info :
CID : 90014A68423861503E030016B720A7A9
MEM : VEN : HYNIX | OEM : 4A01 | DEV : hB8aP>
DAT : Size: 29820 MB, Max.Speed: 52000 kHz, blklen(512), nblks(61071360), ro(0)
EXT_CSD Info :
EXT_CSD rev. : v1.8 ( MMC v5.1 )
CSD struct rev. : v1.2
Supported command sets : 1h
HPI features : 1h
BG operations support : 1h
BG operations status : 0h
Correct prg. sectors : 0h
1st init time after part. : 1000 ms
Min. write perf.(DDR,52MH,8b): 0h
Min. read perf. (DDR,52MH,8b): 0h
TRIM timeout: 0 ms
Secure feature support: 55h
Secure erase timeout : 150000 ms
Secure trim timeout : 150000 ms
Access size : 3584 bytes
HC erase unit size : 512 kbytes
HC erase timeout : 600 ms
HC write prot grp size: 8192 kbytes
HC erase grp def. : 0h
Reliable write sect count: 1h
Sleep current (VCC) : 8h
Sleep current (VCCQ): 9h
Sleep/awake timeout : 419430400 ns
Sector count : 3a3e000h
Min. WR Perf. (52MH,8b): 78h
Min. Read Perf.(52MH,8b): 8ch
Min. WR Perf. (26MH,8b,52MH,4b): 46h
Min. Read Perf.(26MH,8b,52MH,4b): 46h
Min. WR Perf. (26MH,4b): 1eh
Min. Read Perf.(26MH,4b): 1eh
Power class: 0
Power class(DDR,52MH,3.6V): 0h
Power class(DDR,52MH,1.9V): 0h
Power class(26MH,3.6V) : 0h
Power class(52MH,3.6V) : 0h
Power class(26MH,1.9V) : 0h
Power class(52MH,1.9V) : 0h
Part. switch timing : 1h
Out-of-INTR busy timing: ah
Card type : 57h
Command set : 0h
Command set rev.: 0h
HS timing : 0h
Bus width : 0h
Erase memory content : 0h
Partition config : 48h
Boot partition size : 4096 kbytes
Boot information : 7h
Boot config protection: 0h
Boot bus width : 2h
Boot area write prot : 0h
User area write prot : 0h
FW configuration : 0h
RPMB size : 16384 kbytes
Write rel. setting : 1fh
Write rel. parameter: 15h
Start background ops : 0h
Enable background ops: 2h
H/W reset function : 1h
HPI management : 0h
Max. enhanced area size : 747h (15261696 kbytes)
Part. support : 7h
Part. attribute: 0h
Part. setting : 0h
General purpose 1 size : 0h (0 kbytes)
General purpose 2 size : 0h (0 kbytes)
General purpose 3 size : 0h (0 kbytes)
General purpose 4 size : 0h (0 kbytes)
Enh. user area size : 0h (0 kbytes)
Enh. user area start: 0h
Bad block mgmt mode: 0h
Overall status :
MLC status : 0% - 10% used
SLC status : Not defined
EOL status : Normal ( Less than 80% reserved blocks used )
Done!
Elapsed: 00:01:00
Other identy/reset fail Quote:
MODE : BOOTROM
PORT : 27
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 0004
ERROR : ABORT
Boot done!
Memory Info :
EXT_CSD Info :
HPI features : 1h
TRIM timeout: 0 ms
Power class: 0
Card type : 57h
Command set : 0h
HS timing : 0h
Bus width : 0h
Boot bus width : 2h
HPI management : 0h
Part. support : 7h
Part. attribute: 0h
Part. setting : 0h
Overall status :
Done!
Elapsed: 00:01:00
Operation : Reset Settings/Format FS [ v2.20 ]
Mode : SMART RESET
MODE : BOOTROM
PORT : 27
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 0004
ERROR : ABORT
Boot done!
Done!
Elapsed: 00:00:53
Reconnect Power/Cable!
Operation : Identify [ v2.20 ]
Mode : FLASH
MODE : BOOTROM
PORT : 27
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : SRC : PRELOADER_INFINITY_1
EMI : CNT : 0008
ERROR : ABORT
Boot done!
Done!
Elapsed: 00:00:40
Mode : FLASH
MODE : BOOTROM
PORT : 27
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : SRC : PRELOADER_INFINITY_2
EMI : CNT : 0008
ERROR : ABORT
Boot done!
Done!
Elapsed: 00:00:43
Mode : FLASH
MODE : BOOTROM
PORT : 27
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : SRC : PRELOADER_INFINITY_3
EMI : CNT : 0001
EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : BOOT 2ND DA FAILED!
ERR : 0xC0070004
ERR : DA_HASH MISMATCH
Boot done!
Done!
Elapsed: 00:00:49
Mode : FLASH
MODE : BOOTROM
PORT : 27
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 0001
ERR : 0xC0070004
Error : Fail to init protocol!
>>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
Mode : SMART RESET
MODE : BOOTROM
PORT : 27
Error : Failed to open port!
Mode : SMART RESET
MODE : BOOTROM
PORT : 27
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 0001
ERR : 0xC0070004
